87 maxima cold start
Old Oct 4, 2004 | 10:38 AM
80land's Avatar
i have an 87 maxima that i changed the motor but when its cold its very hard to start but during summer its easy.please give me some input.
Old Oct 4, 2004 | 12:59 PM
cardana24's Avatar
Blown
check out the sticky on the AAV (aka air bypass valve)...if this is bad it will make your car run rough on cold starts
Old Oct 4, 2004 | 02:47 PM
dustingrime1's Avatar
I've got a similar hassle and haven't had a chance to look at the AAV sticky up above.
For the five minutes after ignition I have to keep the rpms around 1k, just till the temp. gauge hits C, then it's good from there. While warming the exhaust sputters a bit, no really a big deal though, right?
I imagine the time it takes to warm-up will get longer as the air temperature takes a dip.
Old Oct 5, 2004 | 05:11 AM
cardana24's Avatar
Blown
yeah, the aav will cause the sputter you hear in the exhaust. I replaced my aav and it helped a lot, but mine still does it some. I went to Nissan and ordered the hose that connects to the aav because mine is cracked...once i get that in I will post as to whether or not it helped or not.
Old Oct 5, 2004 | 08:14 AM
Drjmaxx88's Avatar
How much for the hose I need one also?
Old Oct 5, 2004 | 08:43 AM
cardana24's Avatar
Blown
its like 5 bux
Old Oct 11, 2004 | 12:40 PM
80land's Avatar
Do you mind telling me more about the aka air bypass valve or direct me to the sticky i can't seem to find it.
Old Oct 11, 2004 | 12:59 PM
cardana24's Avatar
Blown
its the sticky called air regulator repair....that has more info than I can give you off the top of my head
Old Oct 11, 2004 | 01:06 PM
80land's Avatar
So it would be a good idea to check everything to do with the air regulator or do you know where specifically the valve is located.Thanks a lot.
Old Oct 11, 2004 | 01:15 PM
cardana24's Avatar
Blown
ok, when you are looking into your engine bay from the front of the car, you see your motor, you see your plate that says 'Nissan, 3000' on top of the intake manifold....well its right behind that in your line of site when looking in....behind the middle of the intake manifold...it is about 6 inches long and it has an electrical connection on the left side (when looking in) and a vacuum connection on the right side. Hope this helps.
Old Oct 11, 2004 | 01:23 PM
Drjmaxx88's Avatar
There is a picture of it in the sticky cardana told you about.
Old Oct 11, 2004 | 01:40 PM
80land's Avatar
Thanks a lot but could you please direct me to the sticky please.A diagram goes a long way.
Old Oct 11, 2004 | 02:43 PM
86Wagon's Avatar
Here's a link...
http://forums.maxima.org/showthread.php?t=191348
Scott
Old Oct 12, 2004 | 11:39 AM
80land's Avatar
I very much appreciate all that you did for me and everyone for that matter.Am going to try that this weekend and i hope i come out shining.Thanks.
maxinout93
Oct 27, 2015 01:29 PM
02PearlSE
Oct 7, 2015 02:12 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
