RPM Summit Switch install
Old Oct 8, 2004 | 11:15 AM
Zipp028's Avatar
Does anyone have a write up of how to set the rpm summit switch? I remember reading that nealoc i think has a write up.. But i am yet to find it..
Old Oct 8, 2004 | 12:42 PM
AntiVelvet's Avatar
I need to know too, someone please reply.
Old Oct 9, 2004 | 10:16 AM
Zipp028's Avatar
i am statring my install today it would be great if you know anything about the summit rpm switch
Old Oct 9, 2004 | 03:11 PM
Zipp028's Avatar
thanks for the help everyone...
Old Oct 9, 2004 | 04:41 PM
Guinader's Avatar
no problem , well if will someday need to know this info (I'm getting my too)...so... bump
Old Oct 9, 2004 | 08:48 PM
chuckie311's Avatar
all you have to do is follow the instructions that came with it. its not that hard. you hooking it up for mevi?
Old Oct 9, 2004 | 09:17 PM
Nismo98's Avatar
Where is the best place to get one?
Andrei
Old Oct 9, 2004 | 09:21 PM
chuckie311's Avatar
http://store.summitracing.com/defaul...Ntt=rpm+switch
put this in for part number search..... SUM-830449
Old Oct 9, 2004 | 09:46 PM
Nismo98's Avatar
Andrei
Old Oct 10, 2004 | 07:26 AM
Zipp028's Avatar
yes i have the mevi in but i have a rough idel.. and it stalls out.... thats my only problem.. i havent put in the summit or the solinoid or the vaccum in yet...
Old Oct 10, 2004 | 08:02 AM
I30tMikeD's Avatar
you most likely have a big vacuum leak...are you sure the MAF is pluged in?
The summit install is straight forward. Tap of the ECU for the rpm signal. Get power from either the battery or a source like the cig lighter fuse. The activation wire goes to the solenoid, and the ground goes to ground. The grey wire is not used
Old Oct 10, 2004 | 10:32 AM
AntiVelvet's Avatar
When you say tap the ecu, do you mean open it up or just cut into one of the wires coming from it? If its just a wire which is it? color?
Old Oct 10, 2004 | 01:39 PM
Zipp028's Avatar
what about the yellow wire?
Old Oct 10, 2004 | 01:46 PM
I30tMikeD's Avatar
You tap the rpm signal wire.
Old Oct 10, 2004 | 01:55 PM
Zipp028's Avatar
mike, i have a vaccum problem check out my other thread see if you can help me..
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
TheMafia
Sep 4, 2015 08:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
