engine restorer
Old Apr 11, 2001 | 10:55 PM
MikeyMax's Avatar
Has anyone used the engine restorer in their max?
just curious...cuz, I was reading car and driver, and saw a chart that raised almost 30 psi of compression in a V6 engine. Is this bull****?
Old Apr 11, 2001 | 11:03 PM
annimax's Avatar
Yea It's bull
I'm no expert but I have been told by a number of mechanics
that nearly all additives are crap. Enough said!
Old Apr 11, 2001 | 11:35 PM
Lordrandall's Avatar
It's a temporary solution, if that.
Old Apr 12, 2001 | 04:37 AM
Pervis Anathema's Avatar
Before you even consider putting unknown chemicals in your engine, get your compression checked. If you are already in spec, the don't worry about it.
As a general rule of thumb, I would be very suspicious about putting anything in my gas tank but gas and fuel injector cleaner. I don't think it is worth the risk. If Nissan wanted that stuff in the tank, they would tell us about it. I have visions of clogged fuel injectors costing me $$$ due to some stupid additive....
Old Apr 12, 2001 | 06:15 AM
mzmtg's Avatar
Minister of Silly Walks
My friend put some in his 85 Ford Crown Victoria. Using a stopwatch, the 0-60 time dropped from 20 sec to 15 sec. I'd say the stuff works. Only if your engine is in bad enough shape to begin with. I know a stopwatch is no way to measure that, but 5 sec is pretty easy to notice.
Old Apr 12, 2001 | 06:42 AM
nodoubt711's Avatar
what fuel injector cleaner do you guys use and recommend?
any other additives i should use that aren't crap?
what about octane booster?
i dont want to put anything in my car that will damage it.
Old Apr 12, 2001 | 06:48 AM
mzmtg's Avatar
Engine Restorer as referenced in the begining of this post is an oil additive that is supposed to restore compression.
One of the popular fuel injector cleaners around here in Cheveron Techron Concentrate. I try to use it every 3000 miles, when I change my oil.
Old Apr 12, 2001 | 06:59 AM
brubenstein's Avatar
Marvel Mystery Oil is a very good, mild sludge/varnish remover, seal restorer. Add around 8 oz. a couple of hundred miles before an oil change. It can also be used as a flush agent in auto transmissions by adding a few oz. a week or two before getting the fluid changed.
Old Apr 12, 2001 | 07:09 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Old Apr 12, 2001 | 08:34 AM
Synki's Avatar
I dont believe in "Machanics in a Bottle".
Old Apr 12, 2001 | 10:22 AM
mzmtg's Avatar
Re: .........................
Originally posted by bill99gxe
WHAT?
Old Apr 12, 2001 | 10:55 AM
bill99gxe's Avatar
Re: Re: .........................
WHAT?
"3k is a waste of money." There. I said it.
Back to hiding now...
Old Apr 12, 2001 | 12:20 PM
hehe
Old Apr 12, 2001 | 01:11 PM
Jon91SE's Avatar
Pusssseeeehhhh
Re: Re: Re: .........................
Old Apr 12, 2001 | 01:17 PM
Weasel's Avatar
Premium gas (at least the good brands, Mobil, Chevron, etc) contains enough detergents to keep your fuel system clean. You shouldn't bother using those additives more than once a year if even that as long as you're using premium gas.
Old Apr 12, 2001 | 01:34 PM
Green 2kSE's Avatar
I agree with Weasel, use name brand premium gas and your car probably won't need any fuel cleaners. Nissan states in the owner's manual not to use any fuel additives. However, not all gas is created equal, you get what you pay for. I think Chevron's Techron is the only fuel additive that has been proven to work. I read somewhere that Texaco's additive is now the same as Chevron's but I don't know if it's true.
Old Apr 12, 2001 | 04:58 PM
y2kse's Avatar
Then again, not all premium gasolines are equal. Nissan recently released an internal (confidential) bulletin indicating that Unocal 76 gasoline has an additive that should be avoided in Maximas. My dealer called and gave me that little tidbit of information. Unfortunately, I had been using Unocal 76 Premium (92 Octane) for several thousand miles. The net result in my engine was hesitation and detonation.
I recently switched to Chevron Supreme and have been putting Chevron Pro-Gard (basically, Techron Concentrate with a mild injector cleaner) in my gas tank every 1000 miles. Slowly but surely, the hesitation and detonation are going away. But so much for the idea that all premium gasolines are the same.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
Socalstillen
Sep 20, 2015 11:46 PM
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
