Would tire size 245x40x19 fit without any issue??
Old Oct 14, 2004 | 04:55 PM
Woo Cho's Avatar
I'm thinking of getting 19's but I wanted to get the tire size 245x40x19 and I'm jus wondering if it will fit without any rubbing. I'm riding on 245x40x18's right now and I hav no problem. any help would be appriciated.
Old Oct 14, 2004 | 06:04 PM
jkklim's Avatar
post here? http://forums.maxima.org/forumdisplay.php?f=71
Old Oct 14, 2004 | 07:47 PM
Woo Cho's Avatar
I'm debating between these two.
Axis Crux in 19 wit Maxis lip.
Axis Finish in 19 wit Staggered fit
Old Oct 14, 2004 | 09:44 PM
97SEMAXI's Avatar
you'll need 35 profile, as in 245-35-19
40 profile you might have some issues............
Old Oct 14, 2004 | 11:42 PM
turbo_gg's Avatar
I'm running 19" x 8" rims with 245/35-19's, and have plenty of room left to lower my Max. Although, you need to make sure you have the right offset to insure proper fitment within the wheel well, then you are good to go!
Old Oct 15, 2004 | 07:22 AM
stevay's Avatar
there are a few people on here with moderate drops w/245/40/19 and no problems...i remember one saying he rubs a little in the rear over big dips.
Old Oct 16, 2004 | 04:15 PM
C3nthusiast's Avatar
235/35-19 is ideal. The other tires mentioned are a bit taller. Here's a pic on 19 X 8.5" rim.
Old Oct 16, 2004 | 04:19 PM
If you're getting AXIS wheels I think they only come in 8". W/ a 40 series it will be taller. Since the wheel is only 8" a 245 may be too wide. Not that it won't fit but the offset for the AXIS is most likely 35mm and you may lightly rub on a 245 tire. 235/35 is better.
Old Oct 17, 2004 | 02:10 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Many people, including myself, who are running 19x8" wheels (Axis Se7en's for me) are using 245/35/19 tire sizes with no issues.
Old Oct 17, 2004 | 08:47 AM
Triple8Sol's Avatar
I miss the .org!
Is the Crux new? I haven't seen it before, but I like it.
Go with 35 profile. 40 profile will look really silly.
Old Oct 17, 2004 | 09:18 AM
Woo Cho's Avatar
Crux is probably the newest wheel by Axis. I'm gonna get it with 245x35x19 with Maxis lip......2.5" lip in front and 3.5" lip in rear.
Old Oct 18, 2004 | 09:43 AM
Triple8Sol's Avatar
I miss the .org!
NO! Don't get maxis lip. Geseke had it on his Se7en Mods, and it make sit look really stupid. Yes, you get a bigger lip to brag about, but the spokes will look seriously retarded, and your 19's will look like 17's.
Old Oct 18, 2004 | 12:51 PM
Hamy's Avatar
Woo just buy my wheels man...dont get that Maxis lip stuff. Your better off with the real deal.
Old Oct 18, 2004 | 02:24 PM
PearlRalizinG2k's Avatar
i am running 19's with 245/35/19 and the rims are 8.5" wide with +35 offset, no problem!
Old Oct 18, 2004 | 07:41 PM
Woo Cho's Avatar
Thanx fo tha heads up.......lately i've been thinkin about it too, I did had an idea that it'll look stupid in a way.....unless my car would be rear wheel drive with real wider wheel on rear. So, I'm jus gonna get it with reguler setup with 2.5 lip all around.
Hamy I wish I could get ur wheels but I can't pull out the cash like that.......I'm scratching my credit card.......hehe
Old Oct 18, 2004 | 08:33 PM
Triple8Sol's Avatar
I miss the .org!
Don't the Crux cost over $2000 w/tires too?
Old Oct 18, 2004 | 09:21 PM
Woo Cho's Avatar
the price i got for Axis Crux in 19's with Hankook tires 245x35x19 with Maxis lip was $2199 since I'm not gonna go with Maxis lip, I'm hoping that it'll be cheaper.......
Old Oct 18, 2004 | 10:47 PM
Triple8Sol's Avatar
I miss the .org!
Wouldn't be much less prob still over $2000 IIRC.
Old Oct 22, 2004 | 12:20 PM
Nathan's Avatar
I'm one of the guys with the 245/40/19 wheels. After driving it for around 5+ months, I have had no problems with rubbing, and I'm lowered around approx. 1.7 - 2 inches. The wheels look slightly smalled because of the thicker sidewall but nothing that noticeable. I like the fact that I have a little bit more rubber between the road and the rims.
And overall, they are only 3.3% larger in diameter. For more pics, check out my website.
Old Oct 24, 2004 | 07:39 AM
Triple8Sol's Avatar
I miss the .org!
Nathan: I didn't know until just a little while ago, that you had 40 profile. I can't figure out why, but your tires always looked like the standard 35 profile to me. I don't know if it has to do w/the sidewall on that specific tire, or an optical illusion b/c of your specific drop or the style of rim. I know I'd love to have the extra sidewall, if it just didn't look so funny, but yours is the exception so far.
What are you using for your drop?
Old Oct 24, 2004 | 06:26 PM
Nathan's Avatar
Thanks, I'm using Ground Control coilovers and I'm guessing its around a 1.5-1.7" drop right now. I think if I'd go lower, the rims would look even bigger and hide the sidewalls which aren't covered by the fenders at the moment.
ah2002
Mar 9, 2016 01:42 PM
maximaham
Aug 20, 2015 10:23 AM
twotonezed
Aug 16, 2015 11:41 AM
