Sponsored by:
Sponsored by: CARiD
altima/maxima 2002+ transmissions
Old Oct 22, 2004 | 01:25 PM
JClaw's Avatar
I know they use a 6-speed manual in 2002+ Maximas, and that they also use a 5-speed manual on 2002+ Altimas and a 4-speed automatic on both 2002-2003 Altimas and Maximas.
Are the 4-speed automatics and 5-speed manuals the same we have on our 1995-1999 4th gens? Does anyone have the specific name of those transmissions?
Old Oct 22, 2004 | 03:42 PM
Kevlo911's Avatar
Kevlo for President
Yes, same model number. They are stronger than the 4th gen ones.
Old Oct 22, 2004 | 05:46 PM
JClaw's Avatar
So they must be externally identical to a 95 5-speed?
Where did you get the model number, btw? I can't find them on the org or yahoo.
Old Oct 22, 2004 | 06:58 PM
SR20DEN's Avatar
VQ Wizard
'95 - '01 5 speed is the RS5F50A
'02+ 6 speed is either the RS6F51A or the RS6F51H (Helical Limited slip differential.)
'02+ 5 speed Altima uses the RS5F51A
'05 6 speed Altima SE-R uses the RS6F51H
'02+ Sentra and SE-R 5 speed uses the RS5F51A
'02+ Sentra SE-R SpecV 6 speed uses the RS6F51H
'91-'94 Sentra SE-R Uses the RS5F32V (Viscous Coupling Limited slip differential)
Other 5 speed Sentra SE-Rs and some Infiniti G20s use the RS5F70V
Old Oct 22, 2004 | 07:19 PM
JClaw's Avatar
Found this:
http://www.vibratesoftware.com/html_...ons.htm#Altima
Says all 1997-2005 Altimas use same 4-speed automatic, and that all 1997-2004 Maximas use the same 4-speed auto too.
Although nothing specifies the difference between the RS5F50A (1995-2001) and the RS5F51A (2002-2004). Codes are identical except that it's "51" instead of "50".
Also, is there a difference since my tranny is the canadian version (LSD)? My guess is that mine may be "RS5F50V" instead of "RS5F50A"...
EDIT: Also found this:
http://www.drivetrain.com/nissanRS5F50Afwd5sp.html
Maxima RS5F50A 1985-96
Maxima with LSD 1992-96 (Doesn't have the code, dammit!)
Old Oct 22, 2004 | 07:45 PM
SR20DEN's Avatar
VQ Wizard
No. I said the '02 + Maxima 6speeds use the RS6F51A or V
Old Oct 22, 2004 | 08:54 PM
subs1000w's Avatar
92 to 94 se vlsd is RS5F50V
i assume the internalls are the same but the VE/VG has a different bellhousing bolt patern than the VQ
non lsd is as stated above but the 2nd gen uses a taller final drive i beleve 3.42 instead of the 3rd gen 3.90
im going to try to use the 2nd gen final drive in my vlsd tranny to get longer gears and i think it will work
Old Oct 23, 2004 | 03:03 PM
JClaw's Avatar
So the altima 2002+ tranny has the same bellhousing as the 95-01 VQ tranny.
Old Oct 23, 2004 | 03:27 PM
SR20DEN's Avatar
VQ Wizard
All VQ bellhousings will bolt upto all VQ engines. But the flywheel/clutch/crank tigger combos vary quite a bit bewteen vehicles.
Old Oct 23, 2004 | 07:22 PM
JClaw's Avatar
And there's no way to confirm it will fit by looking at what the numbers/letters mean on the transmission names? Even 5-speed for 5-speed?
Old Oct 23, 2004 | 07:41 PM
SR20DEN's Avatar
VQ Wizard
Confirm what? I said ALL VQ bellhousings will fit on ALL VQ engines. But a 50A bellhousing for a KA, etc. IS different than one for a VQ.
Old Oct 23, 2004 | 07:48 PM
JClaw's Avatar
I'm not talking about bellhousing, I meant flywheel clutch and crank trigger. Tilley supposedly did it, but he did not really tell us how much work he had to do to make it fit. I guess there's no real way of knowing until I drop the engine in and see for myself...
Old Oct 23, 2004 | 08:03 PM
SR20DEN's Avatar
VQ Wizard
The '95-'01 crank triggers, flywheels, clutches can be shared. The '02+ FWD crank trigger, flywheel, clutches are different. The '03+ RWD setup is slightly different still.
Old Oct 24, 2004 | 04:18 PM
JClaw's Avatar
Then how did he mate a 3.5 block with his 5-speed tranny without modifying crank/flywheel and clutch trigger?
Old Oct 24, 2004 | 05:48 PM
SR20DEN's Avatar
VQ Wizard
He still used the cars existing ECU. Therefore he didn't and didn't need to.
Old Dec 7, 2010 | 11:28 AM
Cebby's Avatar
Old thread revival...
I researching LSD Automatics, I found one entry (somewhere) that said 2002 Altima 3.5 Automatics were stronger than our 4th Gen Autos and included LSD's.
Can anyone confirm this?
Old Dec 20, 2010 | 05:34 PM
2002AltimateV6's Avatar
They did not come with LSDs.
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
