Hi-Beam issue
Old Oct 22, 2004 | 04:18 PM
Bob92se's Avatar
Hi-Beam issue
My high beams recently failed and I need to get a inspection sticker. Both low beams work, bulbs are good, fuse is fine and relay looks ok. Any suggestions?
Thanks guys............
Old Oct 22, 2004 | 04:43 PM
Greeny's Avatar
¯\(°_o)/¯
Buy a new turn signal stalk.
Old Oct 22, 2004 | 04:45 PM
Greeny's Avatar
¯\(°_o)/¯
Here is a link for ya. http://www.autozone.com/servlet/UiBr...ADLIGHT+SWITCH
Old Oct 22, 2004 | 05:49 PM
ghostmax's Avatar
I removed mine from the steering column, opened it carefully, cleaned the contacts, put everything back together, and they worked fine! You might try the same thing. Just be careful when you open it since lots of small springs will like to fall out. Has worked for others as well.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
