Ex Manifold studs - manifold
I noticed my engine would tick when cold, but gets quieter after it warmed up. Took a look at the ex manifold studs and sure enough, two of them were gone on the front. The bummer part is that I had them replaced before (well, it has been about 90K since then). I have 167k miles now.
I figured I'll do it myself this time to save some $$$.
The manifold studs, nuts and the gaskets are priced comparably from many sources, but the question I have is the manifold.
Does this need to be replaced? Last time, it was warped, hence it was replaced. If so, what's the best place to get a good deal (on-line)?
I looked around a few places, but they all show the rear side manifold in stock, but not the front.
Thanks,
Thanks,
btw, get the studs from a turbo z....
write-up on replacing studs...
I believe those part #s are correct. WHile you have the manifold out, check to see if it's warped. It isn't too bad of a job (the fronts) I think I could get it down to 4 hrs if I did it alone. The rears on the other hand, are the biggest bi### of all. G/luck
