EGR or not to EGR?
Old Nov 4, 2004 | 03:56 PM
japmaxSE's Avatar
Go Get a Life!
EGR or not to EGR?
I was thinking of going away with the EGR, when I looked at my IM it was covered in black guck. I know the EGR is for Emissions only but there are lots of other little hoses conecting to it. So could it be done or will I have problems?
Old Nov 4, 2004 | 04:02 PM
krismax's Avatar
Father of the 00 VI
Maybe BSWITHTF can posts his pics of what and where he took the rgr stuff off . He took his whole system off
With what im doing i have to take it off too. Guy from JWT gave me some resisters to fool the ecu with. Just have to find where i wrote it down and who knows if it will work
Old Nov 4, 2004 | 07:59 PM
stephenlc's Avatar
I have the 2000 vi coming in the mail do you have to block off the egr system? How many egr ports are there?
-block?
-intake manifold?
-rear header?
Are those correct and are there any other, I want to take out the whole system too?
Old Nov 5, 2004 | 06:09 AM
nismology's Avatar
Well EGR reduces combusion chamber temperatures at partial throttle where the A/F ratio is close to 14.7:1 (stoich). If you don't run the EGR the combustion temps might get so high that they cause knocking and the ECU will retard timing. Apart from being bad for the environment, no EGR might cause partial throttle hesitation in the mid-range. I should know, my EGR is temporarily disconnected and I get that hesitation from time to time. WOT is fine though.
Old Nov 5, 2004 | 06:55 AM
MaDMaX024's Avatar
i've removed my EGR system along with bypassing my PCV..my intake manifold stays as clean as a whistle and the car actually runs better but that may be from a non-working EGR system but i'll never know as i cannot find the valve, cut the tube and plugged the vac line. the black soot is from the EGR, the oily buildup is from the PCV, together they make mud. not sure what your ECU is going to say about removing the EGR i know mine hasnt thrown a code yet for anything (even when i initially started the car and didnt have the MAF or O2 plugged in :doh: )
Old Nov 5, 2004 | 03:30 PM
japmaxSE's Avatar
Go Get a Life!
So you just unpluged it? nothing else.
Old Nov 6, 2004 | 06:04 AM
Nismo3112's Avatar
Custom User Title
I have mine temporarly disconnected, no problems so far, but I did get the EGR check engine code once, but thats it.
Old Nov 6, 2004 | 06:35 AM
nismology's Avatar
Well my EGR system is clogged so i just disconnected the vacuum hose to my EGR valve. Seems to be running slightly better. Gonna have it cleaned out eventually though.
Old Nov 6, 2004 | 12:06 PM
Mizeree_X's Avatar
Getting back to his roots
At WOT the EGR valve stays closed so I really don't see much of a point in disconnecting it for the 1-2HP it may give you at partial throttle. It has lots of benefits, too.
Old Nov 6, 2004 | 02:55 PM
MaDMaX024's Avatar
as far as i'm concerned the EGR causes more problems than its worth.
in my specific case, my EGR caused strange idle (high, low, hunting, stalling), inconsistant EGT at idle, a slight stumble at low throttle. i plugged the vac line, cut and welded the tube shut, removed the valve and used a gasket and block plate. i'm guessing my system was very broken because i know it shouldnt do that..the only benefit i see from removing a good working EGR system is that the intake manifold wont get a ton of carbon in it..
Old Nov 6, 2004 | 03:39 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
my 99 cali spec is losing egr, evap, swirl cont valve, and about any other unneeded emission item
Old Nov 6, 2004 | 04:35 PM
japmaxSE's Avatar
Go Get a Life!
I'm convinced NO EGR
I just can't imagine all that black guck in my engine after being cleaned
Old Nov 6, 2004 | 06:19 PM
nismology's Avatar
I didn't disconnect it for a HP gain. Read my first reply. I actually said it can hurt performance in the mid-range.:
Old Nov 7, 2004 | 07:57 AM
eng92's Avatar
Actually that is the opposite of how the Toyota guys think. Years ago when I had my Supra, one of the quick and dirty mods to improve throttle response was to disconnect the EGR vacuum line and plug it.
It worked very well however your NOx emissions will increase significantly due to the increased CC temps.
Old Nov 7, 2004 | 09:14 AM
nismology's Avatar
You can't compare a turbo car to an N/A car. Turbo cars are designed to run relatively rich (compared to n/a) during partial throtte acceleration. In our cars, the A/F ratio is close to stoich in closed-loop mode. Since the engine runs so lean in closed loop operation, EGR flow can actually prevent knocking since it lowers combustion chamber temperatures. Remove the EGR, and the engine can knock in muggy weather causing the ECU to pull timing, reducing power in the mid-range. Turbo cars don't have this problem necessarily.
Old Nov 7, 2004 | 10:18 AM
eng92's Avatar
I wasn't comparing turbo to NA.
This was years ago. They didn't start putting turbos on supras till '87. Mine was an 84. They didn't have knock sensors in "those days" to pull timing.
Of course reduced CC temps will reduce the possibility of knocking. You would need to have a map of EGT vs RPM for various throttle positions with and without EGR to know if it is an issue or not.
Old Nov 7, 2004 | 06:48 PM
Broaner's Avatar
2060lbs and falling...
Can someone come up with a definiative answer as to weather or not it lets the engine run better? I'm fairly sure I'm going to disconnect my PCV but I can't decide about the EGR. I can understand that it allows the IM to stay cleaner longer. But does it actually hurt part throttle performance? I'm asking for a positive answer not hypothetical. What are the benifits of the EGR system?
Old Nov 7, 2004 | 08:52 PM
nismology's Avatar
The EGR system basically lowers combustion chamber temperatures to reduce NOx emmisions. Removing the EGR system will cause higher CC temps at partial throttle which might lead to knocking. This knocking causes the ECU to retard ignition timing, hurting performance. I have experienced this in my car with the EGR temporarily disconnected.
With all that said, its main purpose is reducing emmisions. I'll be reconnecting mine as soon as i figure out what exactly is causing my 0302 code.
Old Nov 8, 2004 | 03:09 AM
stephenlc's Avatar
all my car does is ping. I havent heard one other maxima at idol ping like mine does. I don't know why it does it. I need to check my codes.
Old Nov 8, 2004 | 04:21 AM
krismax's Avatar
Father of the 00 VI
My car's egr hasnt worked right in two years and the replacement parts over the years will add up. So its going in the weight reduction hall of fame.
Old Nov 8, 2004 | 06:21 AM
japmaxSE's Avatar
Go Get a Life!
This is the same stuff found in my IM.
Old Nov 8, 2004 | 09:30 AM
stephenlc's Avatar
my egr connected to the intake manifold was so clogged and so extremely hard I had to get it out with a dremel at full speed. Still couldn't get all that junk out.
Old Nov 8, 2004 | 11:21 AM
Timz96SE's Avatar
What kind of octane do you use in your maxima? Your maxima requires at least 91...
Old Nov 8, 2004 | 12:40 PM
stephenlc's Avatar
93 every time. I mean my car pings like no other car. Could it be a valve?
Old Nov 8, 2004 | 08:14 PM
BSwithTF's Avatar
I can't find those pics I sent you, I must have deleted them. Do you still have them?
Old Nov 8, 2004 | 09:02 PM
Broaner's Avatar
How are you guys dealing with the higher temps and knocking issues? Toulene or higher than 93?
Old Nov 8, 2004 | 11:11 PM
krismax's Avatar
Father of the 00 VI
My car runs really hot dont know if its the egr system not working.
I think its the leaking headgasket and old engine with alot more power than stock.
Ill see what happens with my new engine .
Old Nov 9, 2004 | 06:02 AM
stephenlc's Avatar
maybe its revving to 8000 rpm.
Old Nov 9, 2004 | 07:15 AM
Broaner's Avatar
Okay. How 'bout the rest of you? How are you dealing with knock prone combustion chamber? If run with the correct fuel(Above 93) does it all become more powerful? Where are those pics? J/k take your time. I'm removing my IM and rear VC next week and I want to do this while I'm in there. What size resistors did you use and where do they go? I don't remember any sensors back there besides the one with two wires right where the pipe meet the IM. Any others?
Old Nov 9, 2004 | 07:22 AM
Nismo3112's Avatar
Custom User Title
I use 90 octane and my engine runs great with 176k mi. EGR is disconneted BTW
Old Nov 9, 2004 | 07:25 AM
mzmtg's Avatar
Minister of Silly Walks
The resistor would go in place of the EGR solenoid. You could just measure the DC resistance of the solenoid and go form there.
Old Nov 10, 2004 | 11:18 AM
Broaner's Avatar
Which solenoid is this? The one that connects to the IM. I must be blind cause I can't find any EGR diagrams in the FSM. What are they entitled and under which section?
Old Nov 10, 2004 | 12:10 PM
nismology's Avatar
http://photobucket.com/albums/v158/e...ent=vacuum.jpg
Credit: Dave Sz
Old Nov 10, 2004 | 08:05 PM
Broaner's Avatar
Thanks man but I'm 95. Its extemely different. I was working on a 99 last night and it was like I'm in a foreign land.
Old Nov 11, 2004 | 05:10 AM
Stephen Max's Avatar
They are in the EC section of the 95 FSM.
Old Nov 11, 2004 | 11:15 AM
Broaner's Avatar
Thanks. You have a 95 FSM? I've been working off a 99 this whole time. The emissions things are really the only differences. Could you please upload a pic for me of that page. Or maybe just email me the 95 FSM? Hmmm.... Thanks again.
Old Nov 11, 2004 | 11:17 AM
I'll try to remember to bring the FSM to work tomorrow and scan the egr pages for you.
Old Nov 17, 2004 | 10:45 AM
Broaner's Avatar
This article in MotorAge is very informative. It helped me understand what the EGR does for fuel mileage. I really can't sum it up cause there is so much good information in the article. It really makes me wonder if removing it does anything but keep the IM cleaner. I know mine is partially if not fulley clogged. The article also says that if the ECU detects low EGR flow it will retard the timing to protect everything. Due to this informaion I must ask if this is the case w/ the Max ECU. To those that have removed it, have you noticed lower ignition advance? This could also explain why the ignition advance gradually retards as the car gets older. As it gets more and more plugged the advance is retarded more and more. I'll be cleaning this mother like non other when I pull the engine.
Spanishrice, this article says that EGR is not active at all during idle.
BTW, I have a 95 FSM now so I don't need one.
Old Nov 17, 2004 | 05:58 PM
krismax's Avatar
Father of the 00 VI
mine completly off and thats why i will fool every sensor into thinking everythings there, very easy my wiring god joey says.
I know the focus sport ecu disables the egr system ,i wonder why they see the need to do that?Well this is what they say who knows if it applies to our cars???
"EGR system disabled
The Exhaust Gas Recirculation (EGR) system will pull a fraction of the exhaust gases from your exhaust manifold and re-introduce them to the engine. This process results in cleaner air being emitted from your exhaust system, but it also introduces air into the engine that is not only un-metered (is not measured or compensated for by the Mass Air Flow Sensor), but is also extremely hot and reduces the density of the air your engine is taking in. Those of you who are familiar with the "DPFE Stumble" know all-too-well what happens when too much EGR is applied by the engine. By default, the EGR System is disabled at WOT (wide open throttle) from the factory, but disabling the EGR System entirely, with an FS/SCT chip will make the car run smoother and better across the entire power band, regardless of throttle position."
Old Nov 17, 2004 | 06:03 PM
Broaner's Avatar
What is the Focus Sport ECU? That article clearly says that it would make the engine less smooth and less powerful during part throttle. More thoughts please.
