Anyone with 20mm spacers/ Stock wheels and Lowered?
I was wondering if anyone has 20mm spacers in the rear of stock wheels and have been lowered by springs and struts or coilovers. the reason I ask is cause i am getting some coilovers and i have 20mm spacers in the rear. Has anyone done this yet? If so did you have to roll the fender lip that goes in the wheel well? Or did everything clear?
Originally Posted by -ZIPPIN-
Originally Posted by jay23
well if i where u i would just call or check the website www.wheelspacers.com
My first version/try at spacers for the rear were indeed 20mm H&Rs on wheels with nearly the same offset as the OEM 17 inchers and they fit fine, meaning, no rubbing or anything like that.
I replaced the 20mm spacers with 12mm custom-made spacers as I found the 20mm to be just too much.....if I had to pick H&R spacers I would go with the 15mm spacers, not the 20mm ones....
Here's a couple picks of what 12mm spacers look like....
http://www.cardomain.com/id/elgalo
Originally Posted by Fezzik
no matter what. You have tgo have the hubcentric ring on there. Its unsafe to not have it.
Originally Posted by WildmanAL
By getting a flat spacer and just using the hubcentric ring I already have should be fine. The spacers are hubcentric and the ring I'm adding will make it wheel centric.
That I dont know. I have never tried this or heard if its safe. So new one on me. Sorry if I was sounding overbearing
vingodine
45
May 21, 2016 12:46 PM
Justin Kroll
Sep 2, 2015 11:06 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
