Changed main cat still car smells, time for new precat?
Old Nov 7, 2004 | 04:36 PM
Whtmax'01's Avatar
Car was smelling like sulfure badly, i changed the main cat, car still smells, but not as much, should i change the precat also, i have code P0420 ( three way catlysts(manifold)). So is the precat now that need to be changed to reduce the smell ?
Old Nov 7, 2004 | 06:30 PM
[maxi-overdose]'s Avatar
if the cat is new, you should smell something when you break it in. does it still smell after a while?
about the P0420....have you confirmed the cause of it is not the pre-cat failure? there's a TSB for this and sometimes this code is triggered by incorrect ECU programming. you can try to confirm it by disconnect the negative battery cord to erase the code. If it comes back once you start the car, it maybe the precat. if not, it might be the problem described in the TSB.
good luck.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
1992maximase30
Aug 5, 2015 09:27 PM
RealityCheck
Aug 5, 2015 06:18 AM
