Starter Motor, DIY ?
Old Nov 10, 2004 | 08:25 AM
humberto_i30's Avatar
My Started just died yesterday on my 2000 Infiniti I30t and I'm planning to replace it myself, any advice doing this ? Something important to do in the process ? Is normal for a 4 years Infiniti to have this problem ? Thanks in advance to all !
Old Nov 10, 2004 | 08:36 AM
spirilis's Avatar
It happens.
If you have an aftermarket intake it should be easier to get to, otherwise you'll have to rip out the intake to get back there I think. I've never done it, but it looks like a DIY problem.
Old Nov 10, 2004 | 08:59 AM
maseo77's Avatar
check out www.motorvate.ca
Old Nov 10, 2004 | 09:08 AM
Ka$hThaRipper's Avatar
remove your stock airbox to get access to the starter.. u'll need
a swivel joint
two sockets, 15 mm and 17 mm i believe
and a long extension or pipe for more torque
those things are in there tight and they're behind the starter itself
and maybe get soem anti-seize for when u put those long bolts back in (they're about 4-5 inches long)
another note, the harness is difficult to unplug, but keep at it, u should eventually get it.
http://www.motorvate.ca/mvp.php/516
Old Nov 10, 2004 | 09:10 AM
ChromeSE5's Avatar
the harness was a headache for me. But it is easy, just takes some muscle and patience. Might as well do a hyperground kit since you'll have so much empty space.
Old Nov 11, 2004 | 08:16 PM
Thanks for all your help guys, Just went and get my starter repaired, and now the car is starting as when was brand new. Thanks a lot, Easy job, don't need to get ripped by the stealership this time. I'm getting good as a weekend mechanic, after I removed and installed a whole new suspension in my jeep I feel like I can do anything, hehehehe Thanks guys, you are awesome !!!!!!!!
Old Nov 11, 2004 | 08:18 PM
ZIPPIN's Avatar
Mauja He Mauja
how did you get it repaired??
Old Nov 11, 2004 | 08:23 PM
^^ i think the mechanic rips it open and lubricates and/or replace the gears in tehre
Old Nov 11, 2004 | 08:43 PM
The mechanic checked the starter solenoid and was OK, then opened the starter and the carbons were damaged and almost inexistent, very worn, he replaced the carbons and repacked the internal part that looks like a stick full of wire and now the starter unit is woking like a charm. My advantage here is that I can cross the border (to Mexico) and the mechanics there are very knowledge about this kind of parts and very cheap, he repacked and replaced the neccesary parts for only $45 dlls, against $240 that is the price at NAPA for a remanufactured one, I save a lot of money, and labor was FREE ! I did it myself !
Old Nov 12, 2004 | 06:02 PM
midnightmax01's Avatar
you dont even need a lift and all you need is a small number of assorted tools and half a brain..............by the way dont forget to disconnect the negative battery cable first unless you want to weld some stuff.
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
maxima297
Sep 30, 2015 03:32 PM
