Pathfinder Throttle Body?
Not the older one 4th gens are using, since ours has the IAV(Idle Air Valve) built in.
I've wondered if the 2001 VQ35 Pathfinder TB would work or one from another Nissan vehicle. It's worth a look, but the IAV is the catch. It has to have something similar for the ECU to work.
Are you Fed or Cali spec?
Originally Posted by I30swimmer
doesnt matter 2000-2001 uses cable throttle.. not electronic.. i really dont see the advantage of having electronic throttle anyways.... more compnents to break and it weighs more over all.. WTF
Originally Posted by BlackBIRDVQ
Q45 TB is not needed on a such low HP car like Tileys even. Its over kill and it will not work. Q45 TB is good when making over 350HP, not 200.
eGas makes sense....it's a simple solution to the On/Off throttle sensitivity problem us VQ30s have. Instead of a direct connection to the throttle-plate they can't control via enough bypass air, they can program in whatever change rate/delay they want to "smooth" out throttle transitions so it's not so jerky.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
