LED install...
Old Nov 15, 2004 | 11:27 AM
resurrectedmax's Avatar
enthuzed.........
LED install...
Hey everyone,
i just received 50 each 3mm and 5mm blue LED's and was wondering if i could just go ahead and swap every LED inside my car? with the polarity's correct of course.
not too sure what the exact procedure is though. resistors?
HELP!
thanks
-raakesh
Old Nov 15, 2004 | 02:04 PM
frankd121's Avatar
Here's some links...
http://www.alexhsu.com/maxima/ledinstall/
http://www.cardomain.com/memberpage/479058/3
Old Nov 15, 2004 | 03:28 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You can go with 5mm as well
Old Nov 15, 2004 | 05:33 PM
enthuzed.........
sweet, thanks gents
Old Nov 15, 2004 | 07:40 PM
irish44j's Avatar
retired moderator
you will need the correct resistors for certain applications. Most are not a direct swap though...will require some soldering....
Old Nov 15, 2004 | 10:57 PM
Pri63's Avatar
if you need resistors, you can get them from radio shack get the 330 ohm 1/4 watt 5% tolerance. In the next couple of days I plan on putting a write up on how to convert the stock bose unit to blue LED using 3mm LED's...
Old Nov 16, 2004 | 05:28 AM
enthuzed.........
well i ordered my LED's through the current group deal and it came with resistors.
i was just unclear as to which LED's i can straight swap and which need resistors.??
Old Nov 16, 2004 | 06:23 AM
Bl_asd's Avatar
if you order bulb from ebay, you need resisitors. those bulbs are for 3volts..not 12 volts. If you order bulbs from superillumination.come...those bulbs are for 12 volts..and there's appilication on the website. i just got 3mm led for my radio...I need to know how to tell the sides on the board... you need to soilder the led for radio, A/C...window switch..rest of them you don't really have to if you get 12 volts ones
Old Nov 16, 2004 | 06:56 AM
TheBigDu's Avatar
What kind of bulbs do those ambient lights under the climate-control have? Can I make them brighter without even putting LCD's in? Thanks.
-Brian
Old Nov 16, 2004 | 08:11 AM
enthuzed.........
bl asd- by bulbs, you mean LED's right? you can determine the polarity by looking at the design of the bulb. one the above links should help. then match the ones already on the board.
TheBigDu - in my max, there is only one bulb there and it is a regular bulb, such as the ones in the climate control. I have to figure out how to change that also
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
