Problem following axle install
Old Nov 16, 2004 | 08:35 PM
crsdsabers's Avatar
Hi,
I had new drive axles installed on Friday. Saw some ATF on the driveway, checked the level, it's good, drove 500 miles. Still leaking, but level shows OK. Where's it leaking from???? Is my o/d light flashing bad???
Thanks,
crsdsabers
Old Nov 16, 2004 | 08:50 PM
s0ber's Avatar
Sounds like you screwed up that gasket when you changed your axle... I know your supposed to be real careful pulling out your old axle as you can nip some gasket thats there.
Old Nov 17, 2004 | 05:24 AM
hasei's Avatar
日産
Probably the transmission oil seal. I had the same problem after replacing driver's side axle myself. If you didn't replace the oil seal, try that. It's like 10 bucks a piece.
Lakersallday24
Nov 7, 2024 07:31 PM
boomerbrian
Nov 8, 2015 05:10 PM
Starrider
Sep 17, 2015 07:26 AM
kirkhilles
Aug 8, 2015 10:53 AM
