What's the correct part # for spark plugs?
Old Nov 16, 2004 | 08:37 PM
2MuchMAX4U's Avatar
I just bought a bunch of stuff from the dealer. One item being new plugs for my 2k1. I didn't think anything of it at the time but when I got home I looked at the part number of the plugs PFR6G-11, also I looked at the old box that I had from when I replaced the plugs at 50k and it also was the PFR6G-11.
I went to the FAQs and another nissan parts web site and it said PFR5G-11. What's the difference? Was it bad to have used these plugs for 50k. Sould I return then new ones for the PFR5G-11? Is the 6 a colder/hotter type plug?
Old Nov 17, 2004 | 05:55 AM
2MuchMAX4U's Avatar
Anyone know what the part number is?
Old Nov 17, 2004 | 06:27 AM
02MAXSE's Avatar
Maybe this helps:
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
Old Nov 17, 2004 | 08:51 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
they gave you a step colder plug which can rob power and is not necessary if you are not boosted or spraying. return them for the PFR5G-11 if you want the plats in stock heat range.
Old Nov 17, 2004 | 06:06 PM
2MuchMAX4U's Avatar
Ok thanks guys for the input. I spoke to the parts guy and he says that's all they carry. He says that's what they use. Anyways I think I gonna return them. I wonder if I will see some hp increase since I've been using since 50k. So colder isn't any benefit for stock engine, huh.
Old Nov 17, 2004 | 06:08 PM
sloppymax's Avatar
worn plugs can cause power loss or misfires if they get bad but colder plugs can be just as bad if not worse. i would stick with the stock heat range.
MAXSE5SPD
Sep 17, 2022 04:00 AM
cruce91
Sep 20, 2015 10:23 AM
Slamrod
Sep 3, 2015 07:38 PM
A32goldylocks
Sep 2, 2015 06:39 AM
Turbobink
Aug 15, 2015 07:20 AM
