need help with fog lights
im in the process of changing all the lights in my car...i want to get new fog lights and am thinking about getting the h3 sylvania silverstars...any opinions on them.
also can someone please tell me how to go about changing the fog lights....i searched through the how tos and i couldnt find anything
thank you
thank you
i am in the same boat as you ^ bro. I just got the PIAA extreme whites for my fogs and dont know exaclty how to change them either. I know they are a little tricky to do and i couldnt find how to do it either.
If you find out let me know
morovasa@shu.edu
morovasa@shu.edu
hey check out maxiello's car domain page, he gives a detailed description on how to install the foglights, including pics: http://www.cardomain.com/memberpage/224200
it isnt hard to do.....just take off all the cips on the bottom that cover the front end of the car. then go in and disconnect the harness from the fog light. with a flash light look inside, you will see two stubs, the size of a writing pen head. you will need to push those toward the front of the car, while holding the front to make sure they dont fly out with all the pressure you applying. if you want you can use a flat head screw driver to widen the white plastic stub a bit to make it easier to take out the housing, also to push out , it kinda hurts if you use your finger. after that it is easy just take out the old one, drop the new one in and your all done.
I'm gonna be replacing mine in the next few days and these are the resources that I've been using
http://home.earthlink.net/~maxfaq/y2...derprotect.GIF
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
