Clutch slipping. Anything I can do?
Old Nov 18, 2004 | 02:40 PM
Powerman5115's Avatar
My clutch just started slipping and I am going to the track Tuesday. Is there anything I can do to help it. I know you can't stop it but anything would help. And could someone advise me as to how to let the clutch last for the longest time so it won't slip? I know in time it goes bad, but any help? Thanks.
Mooney
Old Nov 18, 2004 | 04:48 PM
mansurxk's Avatar
umm...dont goto the track maybe? its not going to perform how it should anyway, you might as well get some life out of it instead of beating on it at the track.
Old Nov 18, 2004 | 04:49 PM
nadir_s's Avatar
vicodin ... gift of life
you're SOL for the track on tuesday.
Old Nov 18, 2004 | 04:57 PM
It's not slipping real bad, I think. Just whenever I drive hard and I shift into second the RPM's drop slower than they usually do. And I can't get a new one becuase my parents won't let me buy something for my car unless it's broken. So I should really not go to the track?
P.S. What does SOL mean? Sold Out of Luck?
Mooney
Old Nov 18, 2004 | 05:27 PM
Batxel's Avatar
blah
If your clutch started slipping, replace it immediately to risk severe damage to your flywheel. The last thing you should be doing is racing in this situation. Drive like a grandma till you get a new clutch.
Old Nov 18, 2004 | 06:30 PM
SlackR237's Avatar
Rollin' on 'Caps
SOL = **** Out of Luck
You were close
Old Nov 18, 2004 | 06:42 PM
Thanks. So what kind should I get. I was going to get the Fidanza flywheel. I have heard bad things about ACT so that's out of the question. I hear OEM is the way to go? Any comments on what type of clutch?How about this exedy? I am not looking for big performance since I have minor bolt ons, but I am looking for something to last long. I hear Nissan key value is not the way to go either. Please comment.
Slackr237: Thanks. If you do an upside-down exclamation point it looks like sh¡t. I'm not sure if this is a way to get banned or not so sorry to everyone offended.
P.S. Should I go ahead and make a new thread?
Mooney
Old Nov 18, 2004 | 07:02 PM
I30tMikeD's Avatar
Mooney
Rpm's dropping slow? Doesn't sound like a slipping clutch to me. Droping rpm's indicates your in between gears and the clutch is disengaged at that point so no slipage would be possible. A slipping clutch is when the rpm's rise to fast while in gear and your not accelerating....hence the clutch slipping against the flywheel.
If you want you can try adjusting the clutch to grab a little closer to the floor. My clutch was slightly slipping at the track last month and I just lowerd the engagement point a bit and it held better the next week at the track. It is not a fix but it can help to put a little more pressure on the flywheel.
Old Nov 19, 2004 | 02:19 PM
Aight. I heard different, I guess they were wrong. It felt like it was better today than all of last week. I guess I'll how it goes. Thanks for clearing things up and for saving me a few hundred dollars.
Mooney
Old Nov 19, 2004 | 08:43 PM
Maxima lover
I think my clutch is slipping. I was on the highway the other day in 5th and punched it and the rpms shot up for about 1/2 sec then i got the power. Is this a slipping clutch? It fells like I'm driving an automatic. How do you auto guys get around it traffic having to wait for the car to downshift when you punch it?
Old Nov 19, 2004 | 08:50 PM
MDeezy's Avatar
i dont get it.
Mooney
Maybe its just me but you said you cant get money to fix your car unless its broken but you were going to get a Fidanza Flywheel? Put that money toward a new clutch, A lighter flywheel wont help much if you have a bad clutch that cant grab it.
Key valve is a low quality OEM part, no where near the quality of OEM parts but is usually quite cheaper for obvious reasons.
Old Nov 19, 2004 | 09:11 PM
I said my parents won't let me buy anything for my car unless it needs fixed. I was gonna get the Fidanza for performance. I have the money, but don't wanna spend it unsless I need to, and when I get a new clutch I'm going to get the flywheel.
Maxima lover: I heard to find out if it's slipping you go 50MPH in 5th gear, push in clutch, rev to 4000RPM, ad drop the clutch. And if the RPM's don't drop fast then it's slipping. Found if in a thread in the NA forum. Someone correct me if I'm wrong.
Mooney
Old Nov 19, 2004 | 10:10 PM
jcy98maxse's Avatar
Turbo is too much fun!
Mooney
Guess you just have to do a couple of burnouts or redline dumps to make that clutch slip even more so you can get it replace.d. Just Joking.
Don't go to the track on Tues, if your clutch is slipping then u wouldnt get an accurate time anyways so it would be a waste. Same your money, get a Exedy stage one (OEM) or OEM if you don't plan on doing anymore modding, do a stage 2 if otherwise. Don't drop or dump the clutch, that would help with making it last, many times sh*t breaks because of wear and tear but if you beat it up even more, its not gonna last as long. Common sense.
Old Nov 20, 2004 | 07:15 AM
Don't go to the track on Tues, if your clutch is slipping then u wouldnt get an accurate time anyways so it would be a waste. Save your money, get a Exedy stage one (OEM) or OEM if you don't plan on doing anymore modding, do a stage 2 if otherwise. Don't drop or dump the clutch, that would help with making it last, many times sh*t breaks because of wear and tear but if you beat it up even more, its not gonna last as long. Common sense.
I don't know if it is slipping now. I have heard 2 different things. But the days I thought it was, I think the car was just performing differently because now the clutch is like it always has been. So, I might just go to the track, the weather probably won't permit it though, 50% chance of rain. But when you say get a stage 2 if I plan on doing other mods, what other mods did you consider when you said to get a stage 2.(Hope this makes since) Thanks.
Mooney
Old Nov 20, 2004 | 07:07 PM
jcy98maxse's Avatar
spray or boost.
Old Nov 20, 2004 | 07:26 PM
NissanSE98's Avatar
Mooney, come on! We all know your car is slow! ..S.O.L.= Slow Or Lackadaisical...or i dunno.......your car is fine; just drive like your brother.. until the car blows up from driving too fast and then get what ever broke fixed
Old Nov 20, 2004 | 09:02 PM
Well, I think I'm faster than you. I don't want to drive like my brother cause he drives crazy. If my car blows up I'll get pissed, I almost blew my motor once though. I thought you quit the .org? guess not.
Mooney
P.S. Don't plan on boost or N20 anytime soon.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
