gettin new clutch installed on monday....what else should i do or replace?
Old Nov 19, 2004 | 09:55 AM
Jonny98max's Avatar
i just bought a EXEDY Stage 1 clutch kit.....i am gettin it installed on monday.....and i was wondering what else do i need to do besides resurfacing the flywheel?
should i do a tranny flush? change out the transmission fluid?
Old Nov 19, 2004 | 10:17 AM
Zack342's Avatar
slave cylinder, dust boot, throwout bearing
Old Nov 19, 2004 | 10:47 AM
meccanoble's Avatar
Sports Button FTW
check axles, if they have torn boots and u have money to replace, do so since they have to come off anyway. If you have a y-pipe that needs installing, free labor , get your bearing checked so it can be replaced just in case its almost dead or causing leakage, there are other bearings that the tranny connects to the axle with. I recommend replacing those, i hear if they are really worn it might cause leakage?
Old Nov 19, 2004 | 10:59 AM
MaximaSE96's Avatar
Maxima Owner
maynot have to replace Slave cylinder....but TO bearing dust boot is a good idea...tranny flush is a good idea.....may as well while its out
Old Nov 19, 2004 | 11:02 AM
Gen8888's Avatar
While the tranny fluid is out, throw some Redline MT-90 in there. Also if you can afford to buy a new flywheel, pick up a Fidanza. Check your seals as well to see if they are leaking or not.
Old Nov 19, 2004 | 11:43 AM
Flava_24/7's Avatar
Boosted Panda
Rear main seal.
I would replace it wether its leaking or not.
Just because its not leaking now, doesnt mean it wont leak 6 mo. from now.
Unless your doing the install yourself, better to pay the labor of removing the trans once not twice.
CorollaULEV
30
Aug 9, 2021 08:11 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
vanebecker
Aug 17, 2015 08:24 PM
kirkhilles
Aug 8, 2015 10:53 AM
