Car won't go need help now
my car won't move. it's a 97 SE 5spd and i try to shift into any gear and it won't let me shift into the gear. Also when i can put it slightly into R it grinds my gears. I'm gonna lose it need help now! Please help
Thanks,
Robert
Thanks,
Robert
Originally Posted by RemoteMax
my clutch fluid was empty ( not that i know there was such a thing) and anyway when i poured it in the pedal still goes to the ground and i can't shift into gear unless the car is off
Thanks,
Robert
Thanks,
Robert
Ok. You need a haynes manuel. You must fill the clutch fluid up and then BLEED the system. There are two places to bleed the system. check www.Motervate.ca for an idea of the procedure. Right now there is no pressure in your clutch system, so the pedal is stuck to the floor.
First bleed the system. The clutch should then work. Then you have to check for leaks. You may or may not have a leak in the system. I had a similar experience, and merely refilling the fluid and bleeding the system solved the problem.
After you bleed and hopefully determine that you don't have any serious leaks, make sure to check periodically. I've had two seperate leaks.
One in the hose that connects to the slave cylinder. It was pretty major. I would lose enough fluid to bring the level from max to min after about 30 shifts.
The second is still occuring and is coming from the slave cylinder itself. This one requires me to top off the fluid about once a month. I'll get it fixed one of these days.
one other test after you bleed.
once you get the pressure back, push and hold in the clutch for about 30 seconds. If it sticks to the floor after 30 something needs to be replaced immediately. As long as your res is full when you try this you won't have to bleed it again right away.
Is this true, even if his fluid got so low that air is in his clutch hydrolic system?
I never heard of this method before. Nice tip if it is true.
Originally Posted by nadir_s
after u put in the fluid and seal the cap, start pumping it for a very long time and life should be restored to it.
u dont need to bleed it unless u opened it up first and then pumped.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
BobMax
Aug 15, 2015 12:35 PM
