Help! Tranny problem
Old Nov 24, 2004 | 01:22 PM
sanekb7's Avatar
I got a problem with transmission. My transmission does not shift smoothly from 1st to 2nd. And check engine light came on. I got it diagnosed with a scan tool but I couldn't find code in the stickies. My code is P0745 or 1206 - (Line Pressure Solenoid Valve (Automatic Transmission). But when I looked it up in the stickies there is a dead link to it.
Does anybody know what it is?
Old Nov 24, 2004 | 05:00 PM
SHADETREE95's Avatar
I would check my dropping resistor first. I was getting the same code and chased it back to resistor. I had to buy the resistor from nissan $40.
Old Nov 24, 2004 | 09:28 PM
sanekb7's Avatar
Did you replaced yourself? Do you know what does it do? You had the same problem with shifting? Is it hard to replace?
Old Nov 24, 2004 | 10:38 PM
It takes about 5 min to replace it is located by the battery it's got 2 bolts 1 wire. It steps down the voltage to the solenoid pack. Mine shifted like a ton of bricks when it went out. I figured this out after I went and put a solenoid pack in with no results.
Old Nov 25, 2004 | 10:24 AM
sanekb7's Avatar
Which one is it? I'm not a pro at this stuff. I have more pictures if needed.
I was thinking about replacing solenoid pack, but thanks to you I'll try to replace resistor. What I'm gonna do is switch resistor from my parents car, they have the same car as mine, and I will see if this is a problem.
Old Nov 25, 2004 | 01:40 PM
The part you are looking for is directly between air box and the strut tower. You can't miss... it It actually bolts to the tower. The plug will be to the left of it. it's got 2 bolts 1 on top 1 on bottom. I hope it works give it a shot.
Old Nov 25, 2004 | 01:43 PM
sanekb7's Avatar
Thanks. I'll try it.
Old Nov 25, 2004 | 03:49 PM
nick's Avatar
First you ned to check the resistance of your dropping resistor - it sits right behind your air box , unplug the connector and test it with ohm meter - it should read 12 Ohms. If the resistor is within spec - i would look into replacing your solenoid pack inside tranny.
check those links , there is lots of good info there:
http://forums.maxima.org/showthread.php?t=347204
http://www.mobiletek.net/vbinstruct.html
http://forums.maxima.org/showthread.php?t=347828
http://forums.maxima.org/showthread.php?t=348400
http://forums.maxima.org/showthread.php?t=348187
Nick.
Old Nov 27, 2004 | 10:53 AM
sanekb7's Avatar
Thank you all guys! I checked drop resistor and that's where the problem is.
This is awesome web-site!!! I would end up replacing solenoid pack.
I'm so happy!!!
Old Nov 27, 2004 | 06:26 PM
nick's Avatar
Good job !!! I'm glad you got it resolved.
i wasn't so lucky at first - but i have learned a lot during solenoid install.
Nick.
pktaske
May 6, 2016 07:49 AM
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
