LED's in Hazard and rear defroster
The write up is down for the install of leds in the hazard and rear defroster. Ok do I solder the led straight to the brown contact points? Is a resister needed? Thanks.
Also when i pulled apart the hazard switch, alittle metal thing fell out, i dont know where it goes back so when you push in the hazard, it stays in. Does anyone know exactly where it goes. Thanks.
Anyone? I dont know where this pin goes in the hazard switch.
The reason the switch doesn't return when pushed in is because it needs that little triangular piece to guide it on/off and it can't do that without the little pin in place.
The hazard button is annoying to put back together, just take your time as that little pin loves to fall out of place.
If you try the cruise control, be careful there too, it works totally different but also is annoying to put back together, but if you get this hazard done, the cruise will be cake.
Good luck.
jds22
Sep 4, 2015 01:52 PM
