S/C guys: When's the last time you...
Old Nov 28, 2004 | 07:52 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Had to tighten your belt?
I just noticed belt slip as soon as the temperature dropped below 45 degrees.
Time to go under and tighten again.
Old Nov 29, 2004 | 08:00 AM
BlackCat's Avatar
RIP '98 Maxima SE
I'm getting that now as the temperature is falling. I just replaced the 3.33" with the 3.125" and I've had to fiddle with the belt tightness. Overtightening will lead to blower bearing failure so just be careful and tighten a little at a time.
Old Nov 29, 2004 | 04:33 PM
maxlinegtr's Avatar
I was gonna ask that question too...and i still wonder hjow much u tighten it...I know u flex the belt to 90 degrees but, is there another way to measure the the amount of slack?
Old Nov 29, 2004 | 04:39 PM
Blu's Avatar
Blu
the tits
I noticed a little boost drop around 4500 rpms , it gained then dropped then gained somemore and ended up hitting normal peak boost at redline. Im guessing its slipping a little but then catching so should I tighten the belt a little more or leave as is and deal with it. I noticed it was not peaking above 6psi and then once on the road for 20 mins it peaked normal but slipped as I said above. All this was monitered on the defi link system...I had my eyes on the road the whole time .
Old Nov 29, 2004 | 04:42 PM
slimer's Avatar
just just take it for a quick spin to see if there is any slip (aka boost slip). If it holds, I dont tighten anymore, if its still slipping, i do another 1/4-1/2 turn and repeat as necessary.
Old Nov 29, 2004 | 04:44 PM
Blu's Avatar
Blu
the tits
yea thats what I planned on doing but I cant locate my swivel sockets anywhere. I guess they got lost in my move
Old Nov 29, 2004 | 05:28 PM
slimer's Avatar
get a u extension
Old Nov 30, 2004 | 04:34 PM
MAXimumHP's Avatar
I noticed too now that the temp dropped I need to tighten the belt a little.
Old Nov 30, 2004 | 04:37 PM
slimer's Avatar
so you got it replaced after your mishap as union grove i c.
Old Dec 1, 2004 | 02:18 PM
MAXimumHP's Avatar
Oh yeah. I can do it in about two hours without rushing now with all the practice I've had. It's probably a bit loose because of that incident. Only notice it when the defrost (compressor) is on.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
