Replacing Thermostat
Old Dec 3, 2004 | 06:26 AM
kckid1121's Avatar
Any help would be appreciated. Does anyone know the steps/process on how to replace a thermostat on a 1990 Maxima GXE? Thanks.
Old Dec 3, 2004 | 06:35 AM
DanNY's Avatar
Ad·min·is·tra·tor
very very short version...(since it's friday i'll write it)
drain coolant
remove upper radiator hose (for clearance)
remove short elbow radiator hose
unbolt water neck/inlet (4 bolts i think)
pull t-stat out
clean off gasket material
position new t-stat making sure giggle valve is up
set t-stat on engine or water neck..hold it with a dab of RTV (gasket maker)
slap a bead of RTV on the mating surface..(follow instructions on package)
bolt on the water neck....then slap everything back on and fill coolant.
Old Dec 3, 2004 | 06:38 AM
Greeny's Avatar
¯\(°_o)/¯
This might help...http://www.autozone.com/servlet/UiBr...3d801f4c66.jsp
Old Dec 3, 2004 | 11:44 AM
kckid1121's Avatar
I appreciate the help, thanks.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
