Reset 99 ECU by disconnect battery????
Old Dec 3, 2004 | 10:49 AM
edwardh1's Avatar
Will that reset the ecu, if the fault condition no longer exists?
any negative problems?
How long to disconnect?
my pp does not have the same ecu selector screw as shown in the sticky thats why i am asking
Old Dec 3, 2004 | 10:51 AM
chuckie311's Avatar
99 have the screw you just have to stick in a little philliphs screw driver..
Old Dec 4, 2004 | 11:42 AM
chenzarino's Avatar
flat head actually.
Old Dec 4, 2004 | 01:13 PM
njmaxseltd's Avatar
99's have a phillips head screw and it's deeper inside the ECU so you really can't see it. Gently insert a very small phillips head into the hole and you'll feel it catch the screw head. A very small flat blade will also go into a phillips slot, but you really should use the correct screw driver so you avoid any damage.
Old Dec 4, 2004 | 02:30 PM
edwardh1's Avatar
its definitely phillips
why is it labelled idle speed adjust?
Old Dec 4, 2004 | 02:45 PM
zachosz's Avatar
I think disconnecting the battery for ~30min will also reset the ECU, seemed to work on my 97 since i no longer have a CEL
Old Dec 4, 2004 | 04:13 PM
edwardh1's Avatar
what is the range of motion ofthe screw -from where it is set by the factory around to the other stop - 90 degrees???? 180?? 360??
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
bigfrank
Oct 1, 2015 12:51 PM
maxima297
Sep 30, 2015 03:32 PM
