NeoVVL VQ, haha look what I found
Look What I found
Well aparently Nissan made a VQ30 with NeoVVl, its aparently called "VVQ30DE" Someone Japanese should look at this site, could be big news.
Link
Link
Originally Posted by LIUSPEED
that not japanese that chinese ! TW in the website is TAIWAN.
Whats the differences between the gas? I didnt mean swap the engine sorry, I ment take the engine apart and use the Neo technology so we can have dual v's isntead of just doing the 00 intake swap and having it just on the Intake, so now we can have exhaust variables to.
Our gas also has too high of a lead content IIRC and/or some other chemical. The Compression ratio is also able to be higher because of this technology. Most turbo diesel engines have used the DI technology for years. Our gas quality requirements have just not come up to par with some other countries.
I know DI requires a much higher fuel pressure to force the fuel into the pressure of the combustion chamber. I would love see more thoroughly what would be involved to put this into a US maxima. If you have the money go for it. But I would advise researching it quite a bit though.
well, I am in china right now, So I could Frieght a/t for around $300-500 to the states, Who knows what car this engine is in? I think Im going to go junkyard digging soon. But daym the weather is just like chicago up here in Shenyang. ITS COLD! so I have to wait till Spring
The date steam cylinder is direct shoots engine new science and technology - gasoline The engine shape - NEO Di has not been direct shoots the type engine Exploration of the petroleum , 40 years ties again, discharge CO2 in the room effect; To sticksdischarges, after hundred years the sea level rises 1 meter. Has the sea level in Japan to rise 50 centimeters, its granulated substance state seacoast on loses 7 cases. speaking of the steam in the source few sentiments under does not want the wave use, also is not polluted to the nature boundary; Its solution road namely date is direct shoots type NEO the Di engine.
Direct □shoots the engine type engine, the fuel straight sends in burns the room explodes □burns □engine of by the strength. The fuel spatial mix burns, its fuel spatial ratio 1: 15; □causes the engine to live the strength to add; Has Yu? To burn fuel of the room to be spatial 1: 15 mixes steam perform; sets by the engine spatial mouth lives (Valve) the control makes the analogy from this me by the injector, the injection to the injector in the injector; its injector piston moves needs the strength to be big because before states sets in the engine spatial mouth lives the control injection in the injector and not sentiment of configuration in the injector. Generally by the certain speed line, the engine does not need to have very many strength; This If the engine fast elevates, the need are more energy; Thereupon lives the inspiration must mix the engine strength which but arrives needs lives, but may inspiration very many spatial whether fuels imitate the share mix, the law decides; But the fuel (gasoline) the spatial mixture ratio wants to hold in 1: 15, burns law the horse whip, lives causes Mars to fill 1: 15 inflammable beside forms the spatial line in this to burn (this is Cheng ran ); In direct shoots the type engine to be easy to be Cheng Ci? cheng?ran ; Because lives 近於, the engine does not need many energy; Thus the fuel consumption may the province. (外燃 is in addition lower than the common engine, efficiency enhancement; Principal factor of the this namely □province fuel consumption). In direct shot the type still to have one , namely needed Gao li , but the inspiration massive mixes , Yu Ran? direct shot the fuel to steam, walks, mix was low; Mix low is small, thereupon under identical may the common engine inspiration massive mixes .
Date company NEO Di is direct shoots the type engine, "based on □guarantees the line " concurrently under new generation of engine. Because has the concave shape piston, Jin?? shooting, spatial flowed the straight mouth and so on "Next to burn " but has been direct □shoots. also by person's Italy, the operation accelerator pedal lives Needs torsion. "Cheng?ran "burns " two differently burns the way same feeling not to give to gather the control, but province fuel consumption and Shu?gan. Performance of the NEO Di compares the line of VVQ30DE engine in the VQ30DD engine The 10.15Mold fuel consumption improves 20 above, the CO2 displacement is low 20 above; also center the low speed engine fast torsion increases 5-7
NEO Di is direct □shoots the type engine □□: J largely enhances □the province to burn □the consumption, □the few CO2 displacement is direct □shoots the type engine. K because NExT burns □may □the province fuel consumption and □lives Gao?li. L by the NTD control may □□line of □Shu?gan. □is direct □shoots the type engine The common engine in burns □in front of the room, □the gasoline □shoots □the spatial □mix, makes the mix □; Again □the mix □sends in burns □the side. The date □company □□direct [ □shoots the type "NEO Di" the gasoline engine, is □the fuel direct □shoots to burns □the room, may □live ultra thin burns □, largely enhances the fuel consumption (the CO2 displacement □to be low) □□the strength; But □□Shu? line □. Row of □mouth Mars fills □□mouth Burns □the room □concave shape piston Fuel □shooting Fuel □shooting □□mouth Burns □the room Mars fills Row of □mouth
* Is direct □shoots the type engine * common engine Common engine it burns □the way □□to burn □, but is direct □shoots the type engine □"Cheng?ran □" □"□to burn □" □□burns □the way. Cheng?ran □□□burns □ Cheng?ran □the ~ □province fuel consumption burns □way ~ Piston Yu?? the travelling schedule □, □the fuel □shoots; □Mars fills Zhou?? the flammable □mix □. Forms □the fuel outside this to be spatial □□, because completely □thin mix □; □□has surely burnt □burns □the way. □burns □~ □completely □strength Gao?li to burn way ~ □burns the piston to the haustorium travelling schedule □, □burns □□shoots to burns □the room □; Burns □the room □mix □□□□□to burn □. "Cheng?ran □" Gao?li "□burns □" Spatial □gasoline spatial □gasoline □□NTD control Mixture ratio
■ "Cheng?ran □" □"□burns □" □NEO Di gasoline engine new technique □ NEO the Di engine, □□uses "NEXT to burn □" □"the NTD control" two □new techniques □. "NEXT burns □" □is direct □gives 最小限 □, □□burns □Cheng of?ran □□Gao?li the consumption □province □to burn □; □balanced. Also "the NTD control" by □□person's Italy □, the operation accelerator pedal □□lives needs the torsion; □also □Cheng?ran □□□burns □two □differently burns □the way same feeling □not to gather; With □fuel □province, □□□□Shu?gan. NEXT (NiSSan Exguisfely Tuned) burns □ NEO Di burns □the room because has "□the concave shape piston", "Jin?? □shooting", "is spatial □flows □the straight mouth" and so on; Thus □lives □Cheng of?ran □□Gao?li the province fuel consumption □to burn □, this □it "NEXT burns □". NEXT burns □the new technique □
□concave shape piston: Because has the sphere piston which Cheng?ran □needs, □Yu Jun? burnt □still may have clear □but □decides burns □. Jin?? □shooting: But □burns □□enters the piston surface □□position, □does not create the wave □, thus may □to □decide Cheng?ran □. Spatial □flows □the straight mouth: Because the spatial □shape □, attracts □the efficiency good, but □□is high speed (□burns □ □Gao?li. This □spatial □flowed □the straight mouth □in 1997 to use to "R3980GTl" □□□attracts □the mouth to be same □□□thought. □Cheng?ran □□□burns □the aspect to mix □flows □the analysis
To a low speed line of □low □Holland □, the piston □□lives in the horizontal aspect □□, thereupon Mars fills Zhou?? the flammable □mix □; Forms outside this □burns spatially □□□, is spatial □burns □compares □40: 1 because ultra thin burns □, may □the province fuel consumption "Cheng?ran □". Also accelerates □Gao?li □, □lives □the class in the vertical direction, then □the fuel □shoots; Completely □□the mixer, □lives Gao?li. "□burns □" □causes Cheng?ran □□□to burn □□is ideal, the date □company voluntarily grinds □NEXT to burn □. □from □flows in left □Cheng?ran becomes the mix □, □fills along 活塞壁 □the surface to □Mars. But date □company Cheng?ran the □□mixer flows □the promotion to □to flow above the room. □Yu Cheng? burns □□the mix □to flow □the analysis (□example)
左列 □the mixer flows □□the example sentiment □, but □□□the mold □(Simulafion) □is likely same also may □Ming Qi? determine the
nature of.
NTD control: □□the person □needs □, the engine fast □fast, the inspiration spatial □quantity, according to its Italian □operation accelerator pedal, □□□on □□control □, then figures out □the torsion which □□needs to item; An item □torsion burns □□the spatial □quantity with □□Yu?dao to be possible to make the precise control.
□排汽量 (cc) 2,987 Inside diameter * travelling schedule (mm) 93.0×73.3 □□compares 11.0 Most Gao?li (PS/rpm) 23.0/64 million Biggest torsion (kgm/rpm) 30.0/4000
nature of.
Damn that translation is hard to read!
h2kSPiG - too much lead in our gas? We use unleaded gasoline.... if the problem is with our gasoline it must be something else. Hydrocarbons can be arranged a billion different ways, so who knows what petroluem distillation plants do with their oil across the globe....
Ok, about the whole sulfer deal, who cares about that, Im talking about getting the NEO part outa there and adapting it to our current VQ, You know what that and a 00vi will do to your hp numbers. Whoa just thinking about it makes me Jizz, Just adding the V to your intake makes the vq insane, now with both jiz jiz jiz jiz, I still want this thread moved to The NA Performance forums. I think there this thread can get my questions answered, So Mod can you please Move this thread, thank you
jmlee44
Oct 2, 2022 02:13 PM
MaxLvr21
Oct 17, 2015 12:11 PM
