Symptoms of bad coils? here's what i have
Old Dec 9, 2004 | 11:37 AM
viktornguyen's Avatar
1998 max... bosch +4 plat plugs for past 6k miles.
New ECTS, fuel filter, mobile 1 syn, used chevron techron injector cleaner, cleaned throttle body,
Car is stalling alot at lights and stop signs. RPMs very inconsistent. Acceleration studders alot and is very jerky.
Sound like coil problem???
My guesses so far: TPS sensor, knock sensor, maybe wrong spark plug types, IACV, fuel pump, .... should i add coils too???
Old Dec 9, 2004 | 11:41 AM
sterlingmaxima's Avatar
get rid of those boshes you obviously never read teh stickies stick to ngk bro
Old Dec 9, 2004 | 12:04 PM
MaximaSE96's Avatar
Maxima Owner
try NGKs first if problem persists then yes i would ay coils.....BOSCH BLOW
Old Dec 9, 2004 | 06:37 PM
ManualMaxima's Avatar
5th Gen till she dies!
yes accelorating studdering is a problem associcated with coils. I just experianced this and it was 1 of my coils that were messed up. try testing your coils. and pm with which oine and i might have an extra one laying around.
Old Dec 9, 2004 | 07:28 PM
NyCzBuBBa's Avatar
how do u test the coil packs?
Old Dec 9, 2004 | 07:30 PM
TheMax95's Avatar
bump I want to know too.
-Paul
Old Dec 9, 2004 | 07:39 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
if your rpms are jumping around, then most likely its going to be something in your ignition or fuel delievey. what codes are you getting?
Old Dec 9, 2004 | 07:59 PM
Maxine's Avatar
I thought mine problem was with the coils to but it turned out to be a injector on cylinder of course under the im. So i replaced myself and saved $300+dollars. So dont rule out your fuel injectors.
Old Dec 11, 2004 | 07:16 AM
SH*T so how do u go about testing the injectors and coils???? I tried chevron techron to clean injectors.
Car starting to stall alot more now. i need to get this resolved ASAP!!!
Called nissan dealer that they said $79 bucks for diagnostic.
Old Dec 11, 2004 | 07:18 AM
NyCzBuBBa's Avatar
try changing ur MAF
Old Dec 11, 2004 | 07:22 AM
I30tMikeD's Avatar
1. It's not the knock sensor
2. Try changing to NGK coppers or plats. Cheapest possible fix
3. CEL? Any codes?
4. I doubt it is a fuel pump or IACV
5. My guess would be coils, MAF, or the plugs
6. I would try unplugging one coil at a time while the car idles. If the car starts to run worse then it's not that coil. If when a coil is unplugged and no change occurs then you have found your problem. Free, easy way to do some diagnostic.
Old Dec 11, 2004 | 07:32 AM
SH*T!!!! so how do u go about testing the injectors and coils???? I tried chevron techron to clean injectors.
Old Dec 11, 2004 | 07:33 AM
OOPS!! my bad for repost.
Old Dec 11, 2004 | 08:06 AM
I30tMikeD's Avatar
Go buy a haynes manual from any autoparts store, or maybe try what I posted above
Old Dec 11, 2004 | 08:11 AM
Got some SES codes:
01-long 02-short - Mass Air Flow Sensor
05-long 12-short - None Existent in ECU decoder ... wtf is this?
The MAF would cause the big stalling problem??? how much are we looking at?
Old Dec 11, 2004 | 09:08 AM
I think i probably have bad coils though on top of other problems i may be having... not sure if coils could cause any CEL codes, but it feels like the car is running on 5 cyl instead of 6 half the time. The way the engine is reacting feels like something isn't igniting right..
Is there 1 type of coil or several?
From: http://www.nissanparts.cc/catalog/?section=438
I got the following prices for them. Prices are reasonable.
I think there's 1 for Left Side and 1 for Right hand. Should I just go for 1 of each to be safe??
Quantity Part # Description List Unit Price Price
1 22448-31U11 Coil Assy - Ign $78.51 $59.83 $59.83
1 22448-31U06 Coil Assy-ignit $71.92 $54.80 $54.80
1 22448-31U01 Coil Assy-ignit $75.38 $57.44 $57.44
1 22448-31U16 Coil Assy-ignit $75.36 $57.43 $57.43
Subtotal: $229.50
Excuse the newbishnish: Coils are the things that go on top of the Spark plugs right?
Old Dec 11, 2004 | 09:15 AM
TonyGotSkilz's Avatar
Theres two types, front bank and rear bank, and yeah the coils go on top of the spark plugs... If your not getting a Cel though (which would tell u what coil it was) then i don't know if you should bother getting a coil at all... i did and it didn't help so it looks like i wasted my money... first make sure u know what the problem is.
Old Dec 11, 2004 | 08:53 PM
I30tMikeD's Avatar
Subtotal: $229.50
Dude, you did not get a misfire code that would indicate a spark problem. You got a MAF sensor code. That is what you need to be looking at.
Old Dec 11, 2004 | 09:26 PM
anarchy57's Avatar
im in the same position aswell, i wish the CEL came on so i know wtf is wrong! my CEL did come on the other day tho, it was blinking then it stopped...
Old Dec 12, 2004 | 01:11 AM
NyCzBuBBa's Avatar
MAFFFFFFFFFFFFFFFFFFFFF causes stalling........I just changed mine feels like a brand new car. What happens is the sensor of the maf is reading bad air/fuel so causes ur car to run bad. Just the short version if someone wants to EXPLAIN totally go right ahead but that just ur basic problem. Change the MAF and you won't stall.
Old Dec 12, 2004 | 04:07 PM
dsn111's Avatar
Not about stalling...........just doesnt acccelerate cleanly (jumps a bunch when pushing the gas pedal hard) and then on top of that sometimes when the car is stopped at a light and just idling, the engine also feels like it jumps sometimes (slight jerk, or lose of power feeling)......
any more suggestions?
Old Dec 12, 2004 | 05:38 PM
ds03's Avatar
It's a coil problem. Had this happen recently to my 99 and also in the past with my 91. Like was said above, the easiest way to check it just disconnect each plug one at a time and see if one doesn't make a difference (that's the cylinder w/ the bad coil).
Old Dec 13, 2004 | 10:46 AM
Great news guys, put in a new MAF today and car is running like a champ.
Also unplugged my coils one by one and car reacts to each one so i think all my coils are good. Also put in copper NGKs.
But all in all changin the MAF did it. Bought a used one from junk yard for $75 bucks... Dealer woulda charge 400+ i think for one of these.
Thanks for all you help guys.
jmlee44
Oct 2, 2022 02:13 PM
chisam14
Nov 6, 2018 08:56 PM
Andy29
Sep 29, 2015 05:32 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
