HELP! Brake light on ODO
Old Dec 26, 2004 | 01:17 AM
Aznwhitemax's Avatar
Hey, i own a 5spd 4gen max. For sum reason my brake light stays on even tho i put my ebrake all the way down. What could possible cause this problem?
Old Dec 26, 2004 | 01:20 AM
mm347's Avatar
Check your brake fluid reservoir - probably low on fluid.
Old Dec 26, 2004 | 11:11 AM
is this the only thing that can cause the brake light to stay on? thanks for the help
Old Dec 26, 2004 | 11:15 AM
BrentK7's Avatar
i use to have an old sentra. It did it for a while just because of age, then it seemed to fix itself, so i never paid much attention to it. So i guess, i am no help what-so-ever....sorry.
heh.
Old Dec 26, 2004 | 11:37 AM
crazy97's Avatar
When your alternator goes bad, lights on your dash will start turning on. If there is a problem with your charging system lights such as ABS and AIR BAG will also come on. I carry one of those portable battery boosters, paid $80 for it and well worth it. Maximas don't always give much warning before they leave you with no juice on the side of the road.
Old Dec 26, 2004 | 01:01 PM
my brake fluid is kinda low but i doubt it can flip the light one. Does anyone else no what can cause this problem? thanks for help
Old Dec 26, 2004 | 01:23 PM
my brake fluid is at minimum. What kind of brake fluid should i use to fill it up? hopefully this will fix my odo
Old Dec 26, 2004 | 04:33 PM
kcryan's Avatar
get some valvoline sythetic DOT 3 and DOt4 certified its good stuff and its great priced
Old Dec 26, 2004 | 10:39 PM
Spectre's Avatar
Brake fluid refill fixed my problem. Poured a little bit in and no more light.
Old Dec 26, 2004 | 10:41 PM
VIP Maxima
ur brake pads are gone or ur fluid is low. low brake pads = low brake fluid = brake light
Old Dec 27, 2004 | 02:54 AM
mm347's Avatar
This is straight from the owner's manual:
"Brake warning light
This light functions for both the parking brake
and the foot brake systems.
Parking brake indicator
The light comes on when the parking brake is
applied.
Low brake fluid warning
The light warns of a low brake fluid level. If the
light comes on while the engine is running with
the parking brake not applied, stop the vehicle
and perform the following:
1. Check the brake fluid level. Add brake fluid
as necessary. See “Brake and clutch fluid”
in the “Do-it-yourself operations” section.
2. If the brake fluid level is correct:
Have the warning system checked by a
NISSAN dealer."
Use DOT3 fluid and you should be set.
Old Dec 27, 2004 | 05:48 AM
Conrad283's Avatar
I need a truck
Most likely your brake fluid is low.
Old Dec 27, 2004 | 08:24 AM
kcryan's Avatar
not always is it the pads are bad...my resovior(the plastic thing u put the fluid into) leeks where it connects to the master cylinder...somtime i will fix this.
Old Dec 27, 2004 | 09:44 AM
monty95's Avatar
yeah...gotta be brake fluid. The light went off in my 4th gen 5 spd as well...just top off the brake fluid and its allllll good....
Old Dec 27, 2004 | 01:09 PM
XeroX's Avatar
Hella internets
Maybe it just doesnt like you?
BTW, I dont kno if i have enought time to fax those numbers to the folks. I will see if i can do it tomarow. just letting you know.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
