Seat Heater Light
Old Dec 28, 2004 | 11:40 PM
sean33's Avatar
Seat Heater Light
My light for my seat heater when out, anyone know how the heck to get to the light on that?
Old Dec 29, 2004 | 12:16 AM
Nick7455's Avatar
heheheheh, mine just went out today too!! how odd...it is just a small LED so you can just find an orange 3 or 5mm on the net and swap them out.....just pop the switch out with a knife....easy as cake
Old Dec 29, 2004 | 04:02 AM
JSMax's Avatar
Sold
hey it's not a led and if you put a led in there, you will blow the fuse and the led. It's a bulb. Take the switch apart, take the brown rubber holder and bulb into your local dealership and see if they have any they have salvaged from other cars. If not, you'll be going to an electronix store and having to order some.
you'll need to remove the center console. 2 screws at the back and 2 up front by the coin holder. just lift that console up enough so you can get your hands under there and push the switch out. They each have a specific connector so you really cant mess them up when putting them back in. Get a flat head screwdriver and pop the switch apart.
good luck.
Old Dec 29, 2004 | 05:48 AM
JoeB
I used a 3mm LED . Just don't forget to sand the LED and use a resistor. I was able to pop my switch out without removing the console. It is just snapped in there and will pull straight out if you can get something under it.
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
dcardello
Sep 3, 2015 11:44 PM
