Seat Heater Light
heheheheh, mine just went out today too!! how odd...it is just a small LED so you can just find an orange 3 or 5mm on the net and swap them out.....just pop the switch out with a knife....easy as cake
hey it's not a led and if you put a led in there, you will blow the fuse and the led. It's a bulb. Take the switch apart, take the brown rubber holder and bulb into your local dealership and see if they have any they have salvaged from other cars. If not, you'll be going to an electronix store and having to order some.
you'll need to remove the center console. 2 screws at the back and 2 up front by the coin holder. just lift that console up enough so you can get your hands under there and push the switch out. They each have a specific connector so you really cant mess them up when putting them back in. Get a flat head screwdriver and pop the switch apart.
good luck.
good luck.
Maxima30
09-07-2015 06:13 PM
