Need help fast on engine mount
Old Dec 29, 2004 | 09:10 AM
Y-MAX's Avatar
I am about to purchase a front motor mount for my 95 SE 5-speed but the seller listed the mount as automatic and said it's good for manual tranny as well. Could someone confirm that?
Thank you very much and waiting online.
Old Dec 29, 2004 | 09:17 AM
MrEous's Avatar
^ Jeff™
iirc, front and rear motor mounts are the same for 5spd or auto. It's the tranny mount you need to worry about getting the right one with.
Old Dec 29, 2004 | 09:34 AM
Y-MAX's Avatar
Thanks. Reason I asked is that I was looking at some other online stores that sells both and the automatic one is a $40 more expensive(maybe extra sensor or sth., I don't know). Well, as long as the automatic engine mount works in a 5-speed model, I am going for it.
Old Dec 29, 2004 | 09:35 AM
nismology's Avatar
The motor mounts are not the same with autos and manuals. The auto mounts are liquid-filled and are electronically controlled by the ECU
Old Dec 29, 2004 | 09:39 AM
MrEous's Avatar
^ Jeff™
Errr...I did a search online as well and I may have been wrong. I don't know. Hold off till someone else chimes in here.
The motor mount for the a/t was much more expensive and had a different part # than the m/t.
Sorry about the misinformation!
mzmtg's Avatar
Minister of Silly Walks
But, as far as fit goes, they are interchangeable.
Old Dec 29, 2004 | 11:14 AM
Y-MAX's Avatar
If I do put a auto engine mount into my 5 speed SE, would it be better, worse or equal to the correct replacement?
Someone please help...
Old Dec 29, 2004 | 11:16 AM
mzmtg's Avatar
You will never know the difference.
Old Dec 29, 2004 | 11:30 AM
Y-MAX's Avatar
Nismology,
So does the auto engine mount has a sensor or connector with it as it's controlled by ECU? And if the auto engine mount is filled with liquid, does it work differently than our manual engine mount? Just curious.
Old Dec 29, 2004 | 11:33 AM
MrEous's Avatar
^ Jeff™
If there is a sensor then you wouldn't hook it up to anything. You don't have anything to worry about. As Mzmtg said, you wouldn't notice a difference between the 2...besides the price.
wyobbagy
Jan 3, 2023 12:03 PM
6spd4dsc
Mar 4, 2016 05:19 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
spidgeon
Sep 9, 2015 03:36 PM
