!!Help! Installing Summit switch NOW and can't figure out which wire to tap ECU with
I'm in the process of finishing the Summit switch for the MEVI and don't know which wire to tap into for the RPM input. From two threads I've read on the org, the correct wire appears to be the white wire with green lines, but someone else who has done this said the green wire with white lines is the correct one. I'm leaning towards the white/green line, but I'm not positive. Any immediate help would be great. Thanks guys.
UPDATE: We can't find the white wire with green lines, but can see the green/white wire....growing more and more confused....
Thanks for the replies guys. We checked the Haynes manual, and it made it look like getting to the TAM required removing the steering wheel, so we decided to give the wires a try. We went with the white wire with green stripes, and after tinkering with the Summit, we got it to work, or at least light up. Still not sure if the MEVI is opening though.....
And it does say "TAM" right next to the screw on the back of the gauge cluster.
JMag90
Aug 25, 2015 09:17 AM
Viralkill
Aug 17, 2015 10:54 AM
