fstb installation
fstb installation
i saw on the faq section that you need a torque wrench to install the fstb. is this absolutely neccesary? i installed it without using a torque wrench and simply used my ratchet to tighten it tight, but not toooooo tight. is this okay?
thanks for the input
yes you do need it...it you over tighten, the stress induced when the suspension works can strip them off...if they are loose then the can come off...so just play it safe and t.wrench them..you can rent a TW from Sears.
Originally Posted by SEmy2K2go
Maybe if you plan to auto-x your car or something, but nothing torqueing them down to spec doesn't seem overly critical. I've had mine on for about 2 years and no issues.
6 months no problems..
MaxLife17
Jun 27, 2019 01:37 PM
