Stereo Volume Problem
Old Jan 21, 2005 | 12:24 PM
MarkWhit's Avatar
I have a '96 Maxima with original stereo (AM/FM with cassette) and the volume has a mind of its own. It works, then doesn't. It will be set and then blast loud and then I can only turn it down to a certain level. It seems to be OK when I first turn it on and then it goes wacko on me. Any suggestions?
Old Jan 21, 2005 | 12:26 PM
Tyrexx's Avatar
Get a used HU, for now try pushing the **** to one side, there should be one place it works perfect.
Old Jan 21, 2005 | 01:15 PM
Chief Brody's Avatar
I have the same problem. You really need to develope a touch with it. It doesn't seem to like sudden motions, so be real slow with it. The worst is when it gets too loud and you can't get it back down. Not sure I would get a new HU just to have it do the same thing. Unless you can get it cheap.
Old Jan 21, 2005 | 08:23 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
you may have a bad variable resistor. get it changed or get a new HU
Old Jan 26, 2005 | 09:29 PM
MarkWhit's Avatar
Thanks for the advice. I think I will run by a car stereo place and see what they say. Probably say I need one of their nice new fancy stereos, I bet!
Old Jan 26, 2005 | 09:36 PM
Lumberg™'s Avatar
on this site too damn much
mine does the same thing sometimes. seems to only do it when its FREEZING cold out. like 20 degrees and lower.
Old Jan 26, 2005 | 09:58 PM
VIP Maxima
get a compressed can of air and go crazy on the volume **** (use the straw provided). there is a LOT of dust behind the ****. i had this problem and it almost fixed it all the way....
ivorton23
Sep 28, 2015 09:08 PM
EdRomo86
Sep 12, 2015 07:49 PM
Violator
Sep 9, 2015 10:14 AM
TheMafia
Sep 4, 2015 08:26 AM
