Want to know how to install MAF
Old Jan 28, 2005 | 11:40 AM
MrPoisse's Avatar
looked all over the howto section + tsb... is there a write-up on how to change the MAF on 2000 Fed spec?
I did go through all the stickies but not sure on how to search on cardomain for more info...
thanks
Old Jan 28, 2005 | 12:16 PM
silvermax2k2's Avatar
there is not too much to know... take off the intake, then take off the MAFS, then install everything back together. there is nothing that proves to even be moderatly hard... if you have a screew driver, and a pair of plyers, then you are all set.
I'll see if i can dig up a pic and show what to disconnect... but i mean... its realy really easy...
Old Jan 28, 2005 | 09:18 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if you want to just remove and replace the sensor then use a flathead screw driver to push the green connector down. it will pop then pull it back. next you will need torx security bits to remove the bolts on each side. i think its either a 20 or 25. finally use a flat head screw driver to seperate between the housing and the sensor then it should just pull out. push in the new one, reinstall and tighten the bolts. plug up the connector and you are done.
Old Jan 31, 2005 | 10:03 AM
MrPoisse's Avatar
even though pics would make it clearer for me, I appreciate your input a lot guys.
thank you very much for the help.
-ReLLiK-
Apr 29, 2016 06:25 PM
BkGreen97
Apr 2, 2016 05:47 AM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
