Want to know how to install MAF
looked all over the howto section + tsb... is there a write-up on how to change the MAF on 2000 Fed spec?
I did go through all the stickies but not sure on how to search on cardomain for more info...
thanks
thanks
there is not too much to know... take off the intake, then take off the MAFS, then install everything back together. there is nothing that proves to even be moderatly hard... if you have a screew driver, and a pair of plyers, then you are all set.
I'll see if i can dig up a pic and show what to disconnect... but i mean... its realy really easy...
if you want to just remove and replace the sensor then use a flathead screw driver to push the green connector down. it will pop then pull it back. next you will need torx security bits to remove the bolts on each side. i think its either a 20 or 25. finally use a flat head screw driver to seperate between the housing and the sensor then it should just pull out. push in the new one, reinstall and tighten the bolts. plug up the connector and you are done.
ballerchris510
09-10-2015 09:35 PM
