rear wheel camber adjustment?
Old Feb 5, 2005 | 03:15 PM
mix master's Avatar
I was wondering if the camber on the rear wheels can be adjusted? I've been getting bad wear on the inside of both rear tires and they seem to have too much negative camber. From the back, it's easy to see the bottoms of the tires are kicked out a little. I have 15" rims and using a T-square on flat ground measured a 3/8" difference between the top and bottom of the rim which I think is 2.5% if my math is right. Is this normal or too high? I can't seem to find any specs anywhere. Thanks for your help.
Old Feb 5, 2005 | 04:06 PM
JDM_Maxima's Avatar
there is no adjustment whatso ever for a 4th gen max in the rear, if you alignment is out in the rear and nothing is bent. the next best thing for you to do is replace the rear shocks.
Old Feb 6, 2005 | 08:52 AM
RA030726's Avatar
I'm nutty for Nissans
sounds more like a tire pressure issue to me. The only thing that can be adjusted is toe and that involves bending the axle, done by very few shops. This is a common "mod" to the b14-b15 sentra and 200sx for better handling on the track. I dont think anyone has actually done this to a maxima.
Old Feb 6, 2005 | 08:59 AM
96ItaliaSE's Avatar
il massimi bassi
tire pressure, bad struts.............or bent beam and knuckles etc. get it aligned and you will get some more specific answers
Old Feb 6, 2005 | 10:35 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
you can get a camber correction plate. i'd suggest you lookover your parts again. if your frame is bent, then the correction plate will do no good.
Old Feb 8, 2005 | 03:34 AM
mix master's Avatar
Thanks for the help. I'm running 32 psi in the rear tires and I'll make sure to get an alignment.
Old Feb 8, 2005 | 05:27 AM
mzmtg's Avatar
Minister of Silly Walks
Who sells a camber correction plate for the rear of our cars?
Old Feb 8, 2005 | 06:23 AM
killcrap's Avatar
i believe they have to be custom made. one guy was going to charge me $700 to make one from scratch from a cnc machine. i was like no thanks. i know stillen makes one for the front.
Old Feb 8, 2005 | 07:29 AM
Shadow's Avatar
But how would you use a camber plate on the rear. It's a beam axle. On the fronts, it's a strut, so you can use the plate to adjust the camber. On the rear, the beam ties the wheels and suspension together. How are you going to adjust the camber on a beam without bending it?
And to the original poster, you can't get an alignment on the back wheels. If a shop tries to tell you they can, leave immediately. They're trying to scam you.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
