DIY Power Steering Flush
I`m looking to flush the power steering system in my Max myself. I just can`t see paying somebody else $70-$100 for something so simple. Anyone know of a good do it yourself kit? I have seen some flushing fluids that you can use without a machine by disconnecting the return line and pouring the flush into the reservoir while turning the wheel back and forth.
I use the turkey baster method and suck out the reserve a few times and refill it. Do that over a period of a day or two using 2 bottles of PS fluid and you should have a nice refresh of the fluid in the system. Do that every 6 months or so and the system should stay pretty clean.
LEMAR
Suction Device
Originally Posted by RastaManMax
Instead of using a turkey blaster, i used this other suction device i got from Wal-Mart for about $3 or so.
LEMAR
LEMAR
Also, is it okay to have fresh fluid mixed with dirty fluid? Would that cause any problems?
Thanks.
I got mine at Pepboys and its a pump like the bicycle air but with rubber hose1 on one end and and rubber hose2 on the other one. take any liquid from rubber 1 to rubber 2 hand pumping it. it cost me...i dont even remember so it wasn't expensive believe i would of.
Actron Vaccum Pump @ PepBoys
Hand pump by Northern Tools
Found another one. Wonder if this can be used to suck-out fluid. $35 on NextTag.com
http://www.northerntool.com/webapp/w...ite=Performics
damn so changing the power steering fluid is as easy as sucking it out and putting in new fluid a couple times during the day or two? interesting ....
isn't changing it every 6 months too frequent?
Originally Posted by CystumMax
I don't see any reason for Replacing Power steering oil. There is not many moving parts in power steering system. It is not like the car engine oil, or the Tranny oil.
Normal driving eventually causes power steering fluid to be affected by heat, friction and electrochemical degradation. The higher pressure created by hard turns is especially damaging over time. Your power steering fluid starts out clear but eventually turns dark with age. Sludge and varnish build up and prevent the easy turning and responsive handling you have become accustomed to.
A power steering flush safely removes varnish and sludge deposits. It is also the best way to remove wear metals that slowly grind away the power steering internal components, including the power steering hoses, power steering pump, rack and pinion and/or gear box. A Power Steering Fluid Flush thoroughly cleans the vehicles steering system and protects it because the fresh power steering fluid and conditioners revitalize the seals and o-rings.
Flushing Power Steering Fluid at least every 30,000 miles will greatly reduce the chance of premature failure and may result in better handling.
...and no I am not selling anything :-)
Cheers!
Originally Posted by dashingMax
I beg to differ...
Cheers!
Cheers!
Could you tell us what is this "suction device" called? A pic would be greatly helpful!
Thanks.
Thanks.
Mixing fresh and dirty fluid won't cause any problems. The mix will also be very diluted if you cycle out the old fluid 2 times anyways.
LEMAR
I beg to differ...
Cheers!
Cheers!
Indeed!
Originally Posted by nismology
Copy and paste?? Our power steering fluid is Dexron III automatic tranny fluid, which is definitely NOT clear. Proof enough that you didn't come up with that yourself.
Originally Posted by Max96GLE
Just drain out some Power Steering/ Automatic transmission fluid with a liquid soap dispenser pump. Kind of cheesy, but works like a charm.
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
RWCreative
Sep 21, 2015 11:01 AM
ChrisIve
Sep 21, 2015 12:01 AM
ColdCananda
Sep 20, 2015 10:45 PM
