Just replaced water pump...having problems
I just replaced my water pump, it was the hardest thing i've ever done on my car it took 7hrs. I was told that there would be a chain rattling noise for a little while (drive around the block). But I have driven over 20 miles and still hear the noise. Also my main reason for changing the water pump was because of a coolant leak, but its been 2 hrs. since I finished and there is already a puddle of coolant under the front passenger side of my car!! what else could be the problem and how long does this chain rattling noise last??? And since I changed it my check battery light keeps flashing on and off about evry 20 sec. Also my e-brake light comes on simultaniously with the battery light even though its all the way down!! what could the problem be???
dam dude ...... if i were you i would
#1. get the car up on some ramps. then look for a leak........let it idle and look around.
#2 . the position of the car on the ramps will work some of the airpockets out.....
#3. let it cool. then recheck everything ya did.....look around sound like you pulled some wires around or something......good luck
the rattling is bubbles in the system. It's supposed to go away. As for the brake/battery lights comin on and off, that usually indicates a problem with the alternator. Check the belt tensions first... and then have your charging system analyzed for free at kragen/autozone/pep boys.
Jae
Jae
I had the same leak in the same spot. I thought it was the water pump too. When i took it to a mechanic, he said my block was cracked. I think because the previous owner did not keep sufficient anti-freeze in the car during winter or the car overheated too much with low amount of coolant. I'm gonna get a second opinion though. Good luck.
altome15
Aug 10, 2015 07:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
erniel
Aug 8, 2015 09:32 AM
