Draining Break Fluid... can it be done?
Was wondering if break fluid can be drained and does it really do anything?
And in two words, how do you drain it?
I will replace mine soon so I wil add a "HOW TO" with pics.... like the Tranny Flush I did to my car..... that link is on my Sig.
You have to replace the oil just a preventive maintenance......
well, hit 100k this week on original fluid. So was wondering for how does break fluid lasts. I also felt break pedal pressing i bit more easily this morning on first break then before. after first break it was fine.
Originally Posted by Zero Deuce SE
Your BRAKE fluid should be flushed every 2-3 years or so. Over time, it changes color and gets dark. It can also hold moisture in the system and cause rust and corrosion. I use a vaccum pump to flush mine.
Where do you drain it though? I assume you forced it out with the pump, correct?
All you really have to do is bleed the brakes. If you do it enough, all of the old fluid will come out of the bleeders.
Just make sure that you keep an eye on the master cylinder reservoir since it'll go down pretty quick. Just keep topping it off until you see clear/clean fluid come out of the bleeders at the wheel cylinders. DO NOT let the master cylinder run dry. Basically it will suck in air and you'll have more trouble than it is worth...
Did it last weekend. It needs to be done infrequently, because it lasts a damn long time. Some people never change it. In my case my old stuff (in my 97, and I'll do my 00 in a week or so because it's the same) was dark, like ginger ale. The new stuff was white, almost like water.
Look to the brake fluid thread in fluids section right now to cover this. If I do mine soon on the 00 I'll do a write up and try and beat the guy who posted above about his
All it entails is bleeding it until it's all changed.
Forge277
Jun 13, 2016 09:26 PM
Need help
23
Oct 2, 2015 08:56 AM
foodmanry
Sep 24, 2015 12:02 PM
markevans999
Sep 10, 2015 04:29 PM
