Broken Stud Help. Yes, I read the stickies.
Old Mar 1, 2005 | 08:32 AM
jasba's Avatar
Okay, starting to plan my broken stud replacement. I have read the stickies, but was wondering if anyone has any better pictures of replacing the rear studs. I can see one stud that is completely missing, and I am assuming there will be more. I really do not want to pull the engine, but I think my clutch is getting old as well, so I am considering it. Just want any advise on the easiest way to do the rear studs. It looks like I could get to the front ones pretty easily, but the rears, how do you get a drill, even a right angle drill, and the room to work between the engine and the firewall? BTW I am dealing with a 91 SE 5-speed. Thanks,
Jason.
Old Mar 1, 2005 | 01:49 PM
dude88888
Broken studs
I am taking you found the "stickie" on stud replacement. (I wrote it from my experience recently). Anyway, once you remove the cross member, the rear motor mount AND bracket, there is plenty of room to work. (more than i originally thought). I used an air 90 degree drill. they are pretty compact and there is plenty of space between where you are drilling and the firewall.
Old Mar 1, 2005 | 05:01 PM
4dscPat's Avatar
So did you just support the engine with a jack and leave the tranny connected to it;s mounts?
Old Mar 1, 2005 | 05:55 PM
Minty91GXE's Avatar
yes just remove the motor mounts, then the bracket for the mounts, while supporting the engine by the oil pan, then slowly lower it a little bit, there is enough room to work back there with a short drill
Old Mar 1, 2005 | 07:20 PM
bigbob's Avatar
check the manifolds with a straight edge if they are warped u will have to machine them or your new studs will not last long
Old Mar 2, 2005 | 08:17 PM
broncoguy's Avatar
Listen to BigBob. I did my rear studs about 4 months ago, but put a warped manifold back on....guess what I get to do again.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
chisam14
Nov 6, 2018 08:56 PM
mkaresh
Mar 12, 2018 06:48 PM
