LED light on Speedometer Cluster
Old Mar 1, 2005 | 09:24 PM
djx82's Avatar
does anyone know what size the stock bulbs in the GAUGES use? i'm trying to get the WHITE LEDs so it'll be very bright and clean.. please if anyone has done so.. give me a reply thanks.
Old Mar 1, 2005 | 09:40 PM
Trevmister1610's Avatar
oo and i just took my gauges out yesterday to put a chrome cover over them, it would have been easy for me to look then, sorry dude
Old Mar 1, 2005 | 09:55 PM
Kikcaffine's Avatar
194's, get them in red tho with the white faces looks awesome
Old Mar 2, 2005 | 12:12 PM
ChrisCheezer's Avatar
but if your going L.E.D.'s behind your guages you must get the ones that are made for such an application or you will get "hot spots" hot spots lighten only small areas behind the guages and leave the rest dark... i have seen it before and it looks really bad.
-but im using normal 194 red (high quality) bulbs. looks great, lights everything.
Old Mar 2, 2005 | 12:37 PM
djx82's Avatar
thanks a lot guys... so don't get LEDS?
Old Mar 2, 2005 | 12:55 PM
nahh not worth it.. just make sure you get some good bulbs though.. or the color will fade in 2 weeks. .. from red to pink.... hehe
Old Mar 2, 2005 | 03:15 PM
4thgradedropout's Avatar
so how many bulbs do you need?..and you said to get highquality ones...any suggestions on brands?
Old Mar 2, 2005 | 05:10 PM
MaximaBalla's Avatar
Get 4 bulbs. As for brands, I have no idea? Just not APC!! lol
Old Mar 2, 2005 | 05:29 PM
expressinme's Avatar
as ya'll are on the topic of gauges, i tried to switch out my guages to white ones but after moving the needle and reconnected it, my guages read all messed up. So i just went to the junkyard and pulled one, but no my OD dont read from the same point because of the different models. So now i have to find a cluster thats for my car so i can have the OD light up. Was i suppose to pull the needles?? Or just did something wrong?
Old Mar 2, 2005 | 06:39 PM
disgruntled's Avatar
when you said white gauges, did you get the whole unit i.e. with motor and housing? or just the white faces. if you got the whole housing, I believe you can just yank the whole old housing out and swapping new ones in, they are held together by a couple of screws I believe. If it was just the faces, then I can't really answer the question, but this I do know, when trying to pull the needle, first lift the just a tad so that it passes the pin that stops it at 0, and let it come to a full rest, mark that location, then pull, so when you put the new face on, you can align the needled to where it was, then put it back to the 0 position, above the pin again.
Old Mar 2, 2005 | 07:11 PM
i was just tryin to change out to white faces
Old Mar 2, 2005 | 07:25 PM
...first lift needles just a tad so that it passes the pin that stops it at 0, and let it come to a full rest, mark that location, then pull, so when you put the new face on, you can align the needled to where it was, then put it back to the 0 position, above the pin again.
Old Mar 2, 2005 | 07:43 PM
thanks for your help
MR2 T'd
Jul 9, 2021 05:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
