Frustrated: I can't start the max = me in a purple car HELP!
Guys I can't deal anymore. 95 SE being a royal pain in the ****. The car has given up on starting. I had a HUGE list of codes and have managed to narrow them down, I still can't get this thing to start properly. OCCASIONALLY it will start after cranking on it forever. So far I have replaced:
Crank Shaft Position Sensors (POS and REF)
Cam Shaft Sensor
Temp sensor
starter
2 new sets of plugs before I realized that the Cam sensor was flooding the crap out of them and gumming them up in a day
So at this pt. I have about $400 wasted.. well not really but I'm still not moving so it seems that way.
I'm getting a 0402, 0803, 1302, and I don't remember but the evap codes. unfortunately there really is no description on the ecu codes link so what gives here. I know that the 0803 and the 1302 are something to do with the MAF/selenoid/absolute pressure whatever deal. the thing i don't get is that the haynes manual says that there is no absolute pressure valve until 96 and thats the code its kicking. Just as far as a general descrip, the motor turns over and sounds as if its goin to fire and then doesn't. It seems to me that I don't have proper spark or fuel or something of that nature. So if anybody can help me please do, right now i have to drive a PURPLE plymoth Breeze, talk about insult to injury!
Cam Shaft Sensor
Temp sensor
starter
Cam Shaft Sensor
Temp sensor
starter
Cam Shaft Sensor
Temp sensor
starter
I'm willing to put money on it that it is your ignition switch. I would have to crank my car forever until it struggled to start, and then I replaced the ignition switch. Boom, all starting problems are GONE.
Im semi - noob, but i ponder your ignition switch suggestion.
Shouldnt be a bad starter if the car cranks.
Let it crank for a while then pull all the spark plugs and smell inside to see if you smell fuel. I'm sure there's a better way but I cant think of it right now- haha
If you smell fuel in every cylinder then your problem is spark.
You might have a bad ECU. Since you changed all those parts and you're still getting new codes.
Try to get an ECU from a junkyard and see if that makes it better. Or get one of these guys on here to loan you theirs for a few hours.
The start signal fuse is a good thing to check too. But even if you had no start signal the car would start in default mode.
I am fearing the ecu may be bad. I don't want to admit it so I'm not going to. It seems like a spark thing, and the plugs do get wet sometimes. The thing that gets me is that the car will start occasionally. but not when it doesn't want to. I've concluded that either the ecu, condensor, or maf must be the prob, i don't know anything else it could be. maybe i'm just way off.
I doubt its MAF, as it should start even without a maf (though you couldn't go above 2500 RPM). Check all your spark plug wires, and I think you can get like a $5 kit that hooks onto your spark plug to test it for proper spark (noticed it the other day at Meijer, though I didn't bother picking it up at the time). Also, I'm not sure if timing is adjustable on maxima's, but on my 300zx if you set the timing too high or too low, you can run into these problems as well. Also, did you check your fuel filter? A dirty one could cause some problems.
Fuel filter is new, Timing is dead on. Can a MAF work and then not and then work again? I had one time when it started and then wouldn't run worth a crap over 2000 rpm, but once I got it started again it ran ok. How about the condensor? anybody think that might be it?
Can you get your hands on an ECU? As a tester, swap ECUs. You can always sell it later on.
I have a hunch its an ECU problem. But in the meantime get your hands on a voltmeter/ohmmeter and test the coolant sensor, the Crank and cam sensors, and whatever else you can see sensor wise.
You should want to do a compression test at this point as well. Just to make sure the engine is ABLE to start and run.
I had similar probablem. They changed my knock sensor, they put a new starter and a control Valve or something is called and also the evaporation canister (this also fixed my CEL ) . I got it all done at the dealership for about 600.
if the problem is the ECU, the dealership will charge you about... $2000.
Go to www.car-part.com and get someone to ship you the proper ECU. It's listed under Computer Box- Non Engine.
Or you can get ripped off
Lakersallday24
Jun 16, 2019 01:35 AM
= purple
