99 Maxima Vibration In Front End Help!!
Hi,
I bought my Maxima new in 99. I was doing the brakes and the jack slipped away and the rotor landed on the asphalt. Ever since that time the car will vibrate when I go over 60 mph. The force of the car landing was squarely on the rotor. Nothing else hit the pavement. I'm wondering if I screwed up my CV joint and axle. Should I replace these parts. I tried balancing tires, new rotors, with no luck.
Thanks in advance
Thanks in advance
I found a great website that shows the removal of the hub and front bearing. The site is www.motorvate.ca My other problem is that I don't know what side has the bad wheel bearing. Is there a way to diagnose this. It's not apparent which side has the bad bearing when driving? My Max has 100k and I dropped it on the rotor at about 30k so I'm lucky it has lasted this far. After checking out the Haynes repair manual the bearing sound slike a good bet. Thanks
kingw323
20
Oct 21, 2015 08:36 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
laparka66
Aug 6, 2015 09:36 AM
