CamShaft Position Senor (REF)
CamShaft Position Sensor (REF)
my check enginge light came on and i am having trouble starting the car. so i read the code and came out 0407 camshaft position senor (ref). would this have a problem starting the car.
thanks
thanks
Originally Posted by SDB318
the man at the local auto parts said i can just clean it out to see if that works. but the only thing is i just cant get my fat *** under the car
Its a blessing. Dont fix it
The sensor you are looking for is on the oil pan, below your big pulley. To get to it lift the car up, remove the passenger front wheel, remove the plastic engine splash cover by the oil pan, and there it is. Take it out and clean it.
It is highly unrecommended that you use your factory lift in the trunk, but if you really need to be sure to put the parking brake on and try not to kill yourself. The best thing to do is get a 3ton floor jack and jack stands.
I believe you should clean it with electronic parts cleaner (Found at any parts store).
you don't need to jack up the car at all. turn your wheel all the way to the right. remove plastic wheel well cover. locate sensor above oil pan below flywheel. make sure wiring is connected tight. if so, remove and clean sensor. if car still wont start, then replace it.
Originally Posted by PAREDLINE
Its not hard at all. its a little plastic sensor that is under your crankshaft pulley. 2 10mm bolts, pull off the harness, and its out.
Make sure you specify the REF sensor when you go buy it
Look up. You guys need to read and not complain when someone doesn't reply to your post in 5 mins.
It is under the CRANKSHAFT PULLEY. A little Plastic Sensor that sorta looks like a T.
Now go out and change it. You dont need to take the wheel off. You might need to jack up the car or park it up on a curb or something.
That is the POS sensor. not the REF. The REF is on the passenger side. The POS sensor is on the other side of the engine.
thanks
thanks
1. The 0407 corresponds to the CRANK Position Sensor - REF. Not the CAM shaft.
2. Buy a Haynes Manual for starters. That way you won't get flamed as much.
TallTom
57
Oct 14, 2025 05:16 PM
