Oil Pressure sensor
Old Mar 15, 2005 | 09:40 PM
MaximA VlaD's Avatar
Oil Pressure sensor
soon after i bought this max, i looked under and saw the unplugged oil pressure sensor. the connection was dangling right next to it, however all beaten. the plastic pieces were all broken off the sensor housing and stuck inside the connector. i plugged it back in, and when i started the engine i got CEL. I reset the ECU and it came back again. i gave up that night and went to bed thinking i could get the code in the morn... but the CEL was gone when i started the car in the morn... anyone have any ideas as to what has happened and if i should try to extract the code anyway?
and just to make sure, there should be only one connection wire and prong to the sensor right?
Old Mar 15, 2005 | 09:58 PM
SPiG's Avatar
SomePsychoGuy
Well those things leak most of the time anyway. Get one at any auto parts store. They say the OEM one is just going to leak again. I guess try to get a needle nose pliers or something and get the pieces of the old one out.
I would think there would be a code if it was not plugged in at all. I don't remember how many wires are in the connection.
Old Mar 15, 2005 | 10:08 PM
NmexMAX's Avatar
dot dot dot ...
You probably have enough money for it underneath your couch ,.. aka they're ~$5
Old Mar 15, 2005 | 10:53 PM
haha, thanks, i guess not losing anything by replacing it is a plus. just thought it was weird i had no CEL until i plugged it in, and then it went away overnight.
those darn CEL monsters..
Old Mar 16, 2005 | 08:15 AM
SuperFishstick's Avatar
lately when i drive around , brake hard or turn hard, the oil pressure CEL blinks / turns on for a sec or 2 and disapears.. what could it be? I have checked my oil, ( it needs to be changed ) and i have replaced the oil sending unit about a year ago.
Old Mar 16, 2005 | 08:45 AM
KFL's Avatar
KFL
In the event that there is low oil pressure(dying/dead oil pump) the oil cel will trigger. Thus you pull over/stop driving.. no-low oil pressure you engine will blow.
It went away cause the contact was maybe better etc.Also maybe be triggered when you drive around.Just replace the sensor & getting a grip on it is a pain though,,small channel locks work.
Old Mar 16, 2005 | 10:26 AM
thanks, i'll give it a shot.
Old Mar 16, 2005 | 10:42 AM
97SEdriver's Avatar
this place is dead
low oil pressure
I notice some times that the low oil light comes on at stop lights. But I think because I always put in 1 quart of 20-50 in the winter, it will come on when it's at idle. Anyone have experience with either Prolong or Lucas oil stabilizer, that may be a contributing factor in my case.
Old Mar 16, 2005 | 10:45 AM
1FSTMAX's Avatar
the ecu doesnt give a CEL for having the oil pressure un plugged..
Old Mar 16, 2005 | 11:38 AM
so why did it come on for one night when i replugged my oil pressure sensor? wierd
Old Mar 16, 2005 | 11:41 AM
NmexMAX's Avatar
dot dot dot ...
CEL = Check engine light
Red oil pressure warning light = different light altogether
Old Mar 16, 2005 | 11:43 AM
1FSTMAX's Avatar
whats the code number?
Old Mar 21, 2005 | 09:52 PM
i never got a code, it went away in the morning. but now i just played with the connection again, and the CEL is back on. i gotta get the code though. will keep you all posted
gustavison
Oct 4, 2015 06:50 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
