Major Major light issues now!
Old Apr 6, 2005 | 05:57 PM
randy021186's Avatar
ok so by now everyone probaly knows that my car was stolen and striped....ok i got 90 percent back together......
first day i found my car.....all interior lights work..
the only wire they cut was the back wires that lead to the trunk because they stole the dam trunk, all head light would work and interior,
today i realize i moved the turn signal and it flicks very fast-thats wierd because when i moved it the last time there was no flicking and all the dash lights were working and switches.....
so this is wat happens now i can see the bose and the ac lights working but as soon as i turn the head light the bose and ac goes off but the clock always work. and oh yeah the cluster light don't go on!
what can cause the light to do this? fuse? relay? any suggestions?
Old Apr 7, 2005 | 07:30 AM
BLaKtOut's Avatar
for the cluster lights did u make sure your dimer switch is on i know its astupid statement you never knw but you should look into your fuses in relays who knows if something grounded in the process of being ripped out
Old Apr 7, 2005 | 07:36 AM
PRPmax's Avatar
check your dimmer switch. Also the reason for a fast flashing turn signal is because either the front or rear bulb is out.
Old Apr 7, 2005 | 07:47 AM
way2fast95's Avatar
The fast flashing signal is normally there to tell you that your bulb needs to be changed soon, however back in my hon-duh days, we used to short the power to the turn signals and cause both of them to blink really fast. So if replacing the bulb doesn't work, look for a short in that circuit. As for the rest, I would check your fuses and check your dimmer switch, I also had a dimmer switch go out on my old J30 and the cluster wouldn't light up until I changed it.
Old Apr 7, 2005 | 01:14 PM
thanks it was the dimmer switch that was loose.....thanks
Old Apr 7, 2005 | 01:22 PM
JetBlackMax83's Avatar
Bingo check thoughs out
Roymg
Sep 3, 2018 05:10 AM
trasmadean
Jan 20, 2018 05:05 AM
AnsonJ
Jun 2, 2017 01:35 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
doctorpullit
Aug 20, 2015 05:15 PM
