Tranny fluid color???
My tranny fluid is like a dark maroon sorta brownish red color. the car just today gave me a lil problem. When i floored it from first gear, when the car shifted to second gear it kinda lagged a lil before it would shift to second???? WTF does this mean. should i changed the tranny fluid?? should i do my VB upgrade with new tranny silinoids?? Im at a lost here please help
yeah, you could do a drain and fill, but I think if I were you I would do a complete flush. I've been draining and filling every 20k miles since new. So my ATF fluid never really gets old. Draining and filling on a car of your age (what is the mileage?) may not be the best option.
Some will say you shouldn't drain and fill after a certain mileage if you aren't having problems, but I never understood that.
Originally Posted by NOCturnalI30
realllyyyyy where i need to knowwwwww
Originally Posted by BigBadPooH
how often should i change my tranny fluid?
i had slipping pretty early on in my the transmission's life. i had the tcm and solenoids replaced under warranty and all slipping went away. i also do a drain and refill with mobil 1 atf once a year and run a moderate sized tranny cooler.
Color of the fluid doesn't say anything about the viscosity, oxidation, stability, friction quality etc, Nissan trannys are brutal on fluids and a 30,000 mile OCI with dinos and 60,000 with syn is optimal. Oil analysis should say how far one can extend the OCI.
spencerwh1
Jun 30, 2016 05:44 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
