speedometer is dying - help
Old Apr 9, 2005 | 09:42 PM
tyrotrader's Avatar
My speedo stays at zero alot and then after a while will spring to life. Sometimes it dies again while driving. If you bang it hard, that will revive it oftentimes.
Any idea on what I need to fix/replace?
Old Apr 9, 2005 | 09:56 PM
I30_DRIVER's Avatar
hit it harder
Old Apr 9, 2005 | 10:24 PM
PAREDLINE's Avatar
My guess is your car is a Late 1996. built in 1995. 1995 speedometers and odometers are prone to failure. You can bang on it but eventually it will not work. You'll have to replace the speedometer/odometer.
Old Apr 9, 2005 | 10:28 PM
NmexMAX's Avatar
dot dot dot ...
Mine doesn't do that, never has works fine... It's a 1995, manuf. date 3/95 ... 227k ...
kash2776's Avatar
my odometer died on me too. Is replacing that thing easy or a PITA?
Old Apr 10, 2005 | 12:39 AM
Crockpot's Avatar
easy.. http://www.geocities.com/amixam69/ni...ash/index.html
before replacing the entire thing try blowing out any dust on the components and retightening the screws that hold it in on the backside. Retighting the screws on the backside fixed mine...
Old Apr 10, 2005 | 12:45 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
if your speedo/odometer is bad, DO NOT go to nissan. they will charge you about $400 just for the little part that goes in the cluster. just buy a used cluster off someone on the .org for about $50-100.
MR2 T'd
Jul 9, 2021 05:06 AM
maxima297
Sep 30, 2015 03:32 PM
jchronis2552
Sep 21, 2015 05:52 AM
Djsmaxima
Sep 14, 2015 11:58 PM
