What happened??
Old Apr 10, 2005 | 05:56 PM
THT's Avatar
THT
Throbbing member
What happened??
I was driving at about 10mph (just completed turn), my steering wheel became totally unresponsive and every dash light came on. Anyone know what happened or what to check? I don't want this to happen again, especially at higher speeds.
~THT
Old Apr 10, 2005 | 05:58 PM
2 Da Max's Avatar
lol that happened to me when i do peelouts and turn hard, the car shuts off and goes into some safe mode. i thought my cvas were going to pop out
Old Apr 10, 2005 | 06:41 PM
THT's Avatar
THT
Throbbing member
Well, I took the car to the track yesterday and there were prolonged sprints of ~120mph on the way to the track. I've also managed to put over 1,000 miles on the car in two weeks.
~THT
Old Apr 10, 2005 | 06:43 PM
Loe max's Avatar
It sounds like it was about to die on you. Did it start right back up after the turn?
Old Apr 10, 2005 | 06:47 PM
THT's Avatar
THT
Throbbing member
Yep, started right back up. O/D light blinked at me too. But, since then, it hasn't come back so I don't think anything is wrong.
~THT
Old Apr 10, 2005 | 06:49 PM
Loe max's Avatar
~THT
To me, it sounded like the transmission wouldn't downshift into a lower gear, therefore, the engine bogged around that turn. The thing that hinted at that was the O/D light blinking at the time.
Old Apr 10, 2005 | 06:50 PM
THT's Avatar
THT
Throbbing member
Engine was running when I was stopped; it didn't die on me.
~THT
Old Apr 10, 2005 | 06:52 PM
Loe max's Avatar
~THT
AH, I see, I read that wrong then. I was under the impression that you were doing a rolling turn where you didn't stop.
Old Apr 10, 2005 | 06:58 PM
tavarish's Avatar
fwd gone rwd cr00
your ECU just took a dump
Old Apr 10, 2005 | 07:01 PM
THT's Avatar
THT
Throbbing member
Why did it take a dump? I want to avoid this happening again because next time, I could be in traffic...
~THT
Old Apr 10, 2005 | 07:03 PM
Loe max's Avatar
~THT
Do a self-diagnosis and see if anything shows up. Also do the same for the transmission. It does sound like a dangerous situation.
Old Apr 10, 2005 | 07:06 PM
tavarish's Avatar
fwd gone rwd cr00
it could have possibly been a "safe mode" of some kind, or there could have been a short somewhere in the system....i've never really heard of this before, but i'd check my ecu for trouble codes as soon as I could.
Old Apr 10, 2005 | 07:42 PM
THT's Avatar
THT
Throbbing member
Will pull codes tomorrow. Only expect to see 0304 though...
~THT
Old Apr 10, 2005 | 07:45 PM
nismos14's Avatar
§è~® f®ÈÄk
is the alternator alright? has it ever been replaced? thats what happened to my car when the alternator took a **** on me. lights got dim power to all accessories was little to none. check it out
Old Apr 10, 2005 | 07:47 PM
THT's Avatar
THT
Throbbing member
Alternator has never been replaced. How would I test it?
~THT
Old Apr 10, 2005 | 07:50 PM
2 Da Max's Avatar
noo not the altenator bro, the car goes into safe mode at times. it happens to me when i turn hard and do a peel out, or just drive wreckless at times
Old Apr 10, 2005 | 07:52 PM
MDeezy's Avatar
suscribed
Old Apr 11, 2005 | 05:40 AM
Loe max's Avatar
~THT
First get the voltage between both positive and negative battery terminals. If its within 14.1-14.7, its good.
If its out of 14.1-14.7, proceed...
Check the voltage between the positive terminal and a secure metal ground (with the engine running of course). It it now registes 14.1-14.7, then there is a faulty connection to/from the battery someplace or just a dead battery. If its below 14.1, then you have a dying alternator.
Otherwise, just head over to autozone or pepboys ect... they will usually do a test for free. Just ask them what the reading is though, because they told me that mine was 'fine' (They didnt' tell me it was at 11.XXX, I had to glance over and look at the diagnosis tool) and then the alternator crapped out on me a week after.
Old Apr 11, 2005 | 08:02 AM
maxgtr2000's Avatar
KH3 by popular demand
~THT
There was a recall on alternators a while back, make sure you got yours changed.
Old Apr 11, 2005 | 08:16 AM
Loe max's Avatar
I think that recall was for 97+ models
Old Apr 11, 2005 | 09:01 AM
4DRSpeed's Avatar
Project Ruby......
Is this safe mode only on 96 models? Where I work the road is heavily traveled so I usually go down to the next light make a u-turn and sometimes stomp it. Never had the car go into safe mode or anything just burns rubber.
Old Apr 11, 2005 | 07:28 PM
THT's Avatar
THT
Throbbing member
Nissan techs were stumped. And I didn't have any codes...just dead KS as I expected.
~THT
Old Apr 11, 2005 | 07:36 PM
nismos14's Avatar
§è~® f®ÈÄk
i wouldnt be surprised if the alternator is just on its way out and not completely shot. hopefully if it happens it's not when you're in dire need of driving you're car, i had my alt done under recall and it took the dealership 2 freakin days to do it!@*(&@#(
Old Apr 11, 2005 | 07:37 PM
superblack98se's Avatar
I took a hard turn one night, and my car did the exact same thing... it started up, then the next day, my alternator went out at 96K miles, at the Wendys drive-thru window great fun! I had to jump start it 7 times to get to my work about 5 min away. Over there, I tested the alternator, and it was shot....had to recharge the battery and the whole nine. I really suggest getting your alternator tested, or you doing it yourself, there is no harm in doing it. It will probably save you some hassle in the future.
Our alternators aren't the easiest things to replace, actually it is a bish...it took me about 5 hours.
Old Apr 11, 2005 | 08:55 PM
THT's Avatar
THT
Throbbing member
Damn. Looks like I'm skipping class on Thursday to do the following:
1) Put EGR back together and bolt it to 00 VI
2) KS
3) Alternator
Gonna be a long day under the hood.
~THT
Old Apr 11, 2005 | 09:09 PM
Good luck with that!
Old Apr 18, 2005 | 05:15 AM
THT's Avatar
THT
Throbbing member
Replaced the alternator and it happened again, only this time, I accelerated through a left turn. I was probably at 50% throttle. Any thoughts?
~THT
Old Apr 18, 2005 | 06:11 AM
SMX95's Avatar
Your ecu has a virus, reinstall windows.
Old Apr 18, 2005 | 06:21 AM
THT's Avatar
THT
Throbbing member
I tried Ctrl+Alt+Del but all I got was a BSOD. Help! lol
But really, I might have to let the Nissan techs take a whack at the problem...*cringe*
~THT
Old Apr 18, 2005 | 10:03 AM
robkris8079's Avatar
I have had the same thing happen to me in my 92 240sx and in my 99 infiniti G20. I never figured it out. It must be a nissan thing.
Old Apr 19, 2005 | 07:19 PM
THT's Avatar
THT
Throbbing member
No one has any input?
~THT
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
