Squealing sound coming from right front wheel, any ideas?
Old Apr 11, 2005 | 07:21 PM
Kevin's Avatar
First off , the car suddenly started having serious vibrations from the front right side wheel at about 70-80 MPH on the highway. Then i noticed at low speeds a squealing sound coming from the front right wheel. Any ideas what this could be ?
Old Apr 11, 2005 | 07:33 PM
97I30touring's Avatar
you are taking righthand turns too fast
Old Apr 11, 2005 | 07:39 PM
Kevin's Avatar
say what ?
Old Apr 11, 2005 | 07:42 PM
superblack98se's Avatar
lay off the four leaf clovers a little bit...huh?
Old Apr 11, 2005 | 07:52 PM
DR-Max's Avatar
Check your belts. They might be worn down and slipping or the tensioner might need to be tightened a bit. I don't have an answer to why your car was vibrating from the right, front end.
Old Apr 11, 2005 | 07:53 PM
oh snap,,,,
Old Apr 11, 2005 | 08:02 PM
Kevin's Avatar
had the belts replace a couple of weeks ago. noise just started about 3 days ago. doesnt happen when i am stopped, only when rolling and the wheels are moving. you think is still might be related to the belts ?
Old Apr 11, 2005 | 08:12 PM
aprentice's Avatar
bad rotor?
Old Apr 11, 2005 | 09:00 PM
DR-Max's Avatar
The tension on the belt might not be adjusted correctly. Check out this link. It's a part of the "how-to" for replacing the alternator.
Old Apr 12, 2005 | 03:22 PM
genepool's Avatar
Check your axle?
Old Apr 18, 2005 | 07:45 PM
Kevin's Avatar
VIBRATION PROBLEM SOLVED!
it was as simple as balancing the wheels. Squealing problem however is still intermittenly there.
Old Apr 18, 2005 | 08:28 PM
nd4spdgt's Avatar
Any update on the status of your rotor? Take it to a local Midas or something and they'll give you a free inspection, measure your rotors, etc. I took mine recently and found out it was below the discard thickness.
I think I'm having the same problem as you are with the squealing from the front right side. I'm going to replace my front rotors and see if there is any difference. Needless to say I'm going to try to replace my pads and rotors myself tomorrow (Midas quoted me $400 for parts & labor for pads on all 4 wheels and new rotors for the front axle) I went to Autozone and got both sets of pads, the front rotors (nothing fancy), brake cleaner, and some packet of grease all for about $85.
twotonezed
Aug 16, 2015 11:41 AM
BobMax
Aug 15, 2015 12:35 PM
follyburr
Aug 7, 2015 09:50 PM
BassAddictJ
Aug 4, 2015 11:38 AM
Jcof88
Aug 3, 2015 10:43 PM
